Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
Dropped external hd not being recognized
I dropped a barracuda 7200.10 500gbytes. It made noises afterword and would not be recognized by windows except as a local disk ST3500830AS without an assigned drive number. I put it in the refrigerator overnight and still did not work the next day. the power light would go off also after a couple minutes. I swapped power supplies and that did not help.I used R-studio recovery and it would not open the drive files either.
I slapped the hd with the palm of my hand a few times. Now, the system doesn't recognize The drive on startup at all, but the power lght stays on.
I opened the drive to look inside. It appears start to spin ok. Shortly afterwards, the arm jumps every couple of seconds making a clicking sound, and a scratching sounds follows shortly. This lasts for a couple of minutes before it stops spinning altogether. I want to save the data if possible. I don''t know if that moving arm is working the way it is supposed to. Please advise.
Edward
  • ash_4_cash Nov 25, 2008
    Seagate Barracuda 7200.7 80 GB SATA INTERNAL Hard Drive
    stopped booting up. would make similar click noises for a few times, unrecognized in BIOS. after i ran out of patience, smacked it a bit. no use. replaced the circuit board from a working HD of same model / specs, no use. have about 70 GB data on it which is from the last 18 years. Need to recover.
    Genius:
  • 1,066 Answers
Replace the hard drive, as dropping it has rendered it totally useless.  be more careful in the future.
Posted on Apr 01, 2009
Installing 7200.10 with a Windows 7 Home Premium Service Pack 1, 32 Bit OS,. Have placed drive into an external case with USB connection and external power source. Laptop Computer does not recognize this...
it is impossible to install windows 7 to an external drive on any PC. to install it you will have to remove the drive you have in the laptop and then run the setup for windows
Apr 07, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
The Seagate Barracuda 7200.10 500 GB SATA Hard Drive External falled and now is not more recognized by my pc Win XP
Hello
OK, you need to let me know if the drive spins up, you should be able to hear it. Also, you need to have a listen if the drive makes a clicking noise.
Please be so kind tom let me know.
If the drive makes a clicking noise the drive is done, you will need to take it to a recovery institution to recover the data.
If the drive does not spin up, the circuit board or the power cable might be broken.
Hope this can be of help.
Kind regards
Andrea
Jun 17, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 EIDE 160 GB. Computer does not recogniz
Hello
If you plug it in and windows states that the device could not be recognized, try plugging it in in one of the USB ports in the back of your case, This worked for me.
If you just can't see your HD in my computer, try these following steps.
Go to:
Conrtol panel
Administrative tools
Computer management
Storage
Disc management
Now you should see see the drive in the schematic below, then right click on the drive and assign a new drive letter.
Restart, and all should be set.
If this does not work, have a look at the jumper settings on the drive itself. For this you must take the hard drive out of the case again.
Hope this works. Please rate this.
Best regards
Sep 28, 2009 | Seagate Computers & Internet
I have a seagate external hard drive that I dropped, and now the blue light stays on, but the computer does not recognize it. is there a way to retrieve the info?
Are you using XP?
It should show up. Are yo sure you are plugged in correctly everywhere?
Check your device manager ...
Let me know if this works for you.
a
Sep 26, 2009 | Seagate USB 2.0 External Enclosure + 300GB...
Laptop Won't Recognize External HD
You can try opening the device manager in Window XP and uninstall the external hard disk (make sure you show unplugged devices).
Then replug the drive again, and it should reinstall the drivers.
Jules
Feb 22, 2009 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
358 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
