Question about Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
My Frigidaire front loader won't do the final spin & drain. I had a repairman tell me it was the water pump & replaced it but it still is not working. My clothes are soaking wet. I've tried all size loads & nothing works.
  • 5 more comments
  • Anonymous Nov 17, 2008
    I have the exact same problem as above. My front Frigidaire Washer won't "final spin".The pump makes a cracking noise in the "final spin" My clothes are soaking wet and the water just sits in the washer.
    Has any found a solution to this problem yet?
  • foo1 Nov 20, 2008
    Yes! this happens to me all the time.
  • Anonymous Nov 22, 2008
    Front Loader left my clothes in a puddle of water. Washer will not drain or final spin.
  • Anonymous Dec 26, 2008
    my frigidaire washer will not drain or spin in the final spin cycle
  • azhvac85652 Dec 27, 2008
    clothes are wet at end of cycle. Spins and reverses on slow. No spin up to actually remove the water from the clothes.
  • Anonymous Dec 30, 2008
    dispenser valve froze during winter storm, not a big problem, replaced today. did a load of clothes, everything fine till final rinse/spin, nithing. water drains so i know pump is fine, any solutions of where else I might look?
  • Anonymous Jan 01, 2009
    My clothes spin but do not spin fast enough enough to extract enough water from my clothes. They are heavy with water even after two extra apin cycles.
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Posted on Nov 14, 2008
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
My front loader, model #FTF30ES1 won't spin out
This could be due to water discharge. Clean filter/ pump if needd be could also be slow motor speed , worn belt/ brushes in motor. good luck
Nov 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loader nightmare!
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Apr 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Front Loader Frigidaire will not drain model no. LTF530FSO
check to make sure all hoses are not clogged - our washer hose before the pump was clogged due to washing a rug that had deteriorating rubber backing - would not drain until I flushed out the hose that goes from the tub t the pump.
Apr 30, 2008 | Frigidaire ATF6000ES Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
911 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
