Question about GE JVM1650 1000 Watts Microwave Oven
Microwave door catches outer frame
I just bought a GE Spacesaver microwave that was a demonstration model. The unit functions fine, but the door is catching on the outside frame of the microwave toward the top at the hinged side. It makes a popping sound when you open it. I checked it out and I can see where the door is catching on the outer case at a particular point when it is almost fully open. It looks like maybe the door needs a slight adjustment so it won't rub against the outer casing. How can I fix this?
  • pavone Nov 13, 2008
    When the door is closed, the crack between the edge of the door and the control panel is very slightly wider at the top, so I know the door hinge needs to be adjusted. Just exactly how do I get to the hinges? I don't see any screws, tabs, etc that would allow removal of the door cover.
  • pavone Nov 14, 2008
    Good advice all around. Thanks.
    President:
  • 2,712 Answers
Since it is new, simply return it for a model that works. Having a microwave with an improperly fitting door is a major hazard. better safe than sorry...
Posted on Nov 13, 2008
    Sergeant:
    Champion:
  • 324 Answers
You need to lower the panel on the bottom and you will see the hinge screws there. loosen the screws and adjust the door.then tighten the screws. should be a easy fix
  • 734 Answers
This is usually caused by either a bad door switch, a loose door switch mount, a misaligned door hinge, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
  • futureloginn
    futureloginn Nov 13, 2008
    You can find helpful exploded view diagrams and order parts by entering your full model number here.
    There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    Genius:
  • 1,847 Answers
Try adjusting the screw near the hinges.
  • Legin Varghese
    Legin Varghese Nov 13, 2008
    to make adjustment on the hinges, you need to remove the plastic door cover. you need to physically check and adjust.
    let me know if you need more assistance..thank..kevin.
How do I replace kitchenaid microwave door handle?
This is not a fun one if you take a putty knife and go in between the outer door and frame you can release the outer door cover hears the catch over time the door frame becomes brittle so there is a 50/50 chance the frame will break trying to separate it
Feb 18, 2015 | KitchenAid Microwave Ovens
How to remove the outter door frame on the GE Microwave
http://www.repairfaq.org/sam/micfaq.htm
for both queries this site would help somethin i think.. tpugh information is very huge please see if it is useful for u
Dec 25, 2007 | GE Advantium 120 Convection/Microwave Oven
Mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Parts for Model JVM230WLC
Are you looking to upgrade it cosmetically or does it have a problem?
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To replace the outer door panel, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove for disassembly.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jan 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker installed over stove-----need to remove it
Her is a link that I hope with work that shows the bracket and how it was installed.
PDF]
  JVM1850BH/CH/SH/WH – GE Spacemaker Over-the-Range Microwave Oven File Format: PDF/Adobe Acrobat - View as HTML
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL JVM1341WW002 microwave broken door handle!
Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
Ray
Nov 19, 2008 | GE JVM2050 Microwave Oven
Splatters between the screen and the glass on the microwave door
You can find helpful exploded view diagrams for most brands by entering your full model number here.
Those diagrams should show if the screen is glued onto the glass, etc. If so, it makes it harder to clean.
Nov 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
