What do i do if the orange light keeps flashing..
SOURCE: Canon i9950
Five flashes: Print head not installed / Print head not installed correctly / Defective print head
Install the print head. If the print head is already installed, remove the print head and check the electrical contacts for foreign matter, then reinstall.
For the i9950 ONLY: When the CD-R tray is set in the printer, remove the CD-R tray and set the paper output tray to the paper print position, then install the print head.
After reinstalling the print head, you may need to realign it.
If this error still remains, the print head may be damaged
SOURCE: Canon i9950
Yes, the flashing light on start-up is actually the Waste Ink pad is full
a Canon tech suggests that the job is very difficult (unfortunately even for them)
HOWEVER....good news is that you can override it for awhile...
this should resolve the issue
remember
to rate the solutions...anything less than FIXYA actually lowers my
rank...I didn't make the system...just wanting everyone to understand the impact of their vote....so if you need further help...just ask....hope it fixya'd...if it did then rate please!
bearb
SOURCE: reset ink counter for canon mp630
The cartridges have small chips on the lower face Once it registers empty that casette will not woek again. Many of the replacement cartridges that are not genuine have this chip missing. You can transfer the old chip to the new vcartroidge ( if its not a genuine with a replacement reset chip. I think you can by a chip resetter for this model. do a web search fot your model they are por etty cheap to buy
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
