Washer stopped in the middle of a load
Whirlpool ThinTwin stackable washer dryer. The washing machine stopped in the middle of a load, and now won't spin or drain. The belt is fine. Please Help!! (5 kids)
  • diversgirl9 Nov 13, 2008
    Hi! My lid switch does click when I open and shut it, and there's a buzzing sound. Could that still be the problem?
    President:
  • Washing Mach... Master
  • 2,651 Answers
Sounds as if yhou have a lild switch problem , lift and close the machine lid and listen closely for a "clicking " if hte machine doesnt think the lid is down it wonk spin/ drain for saftey reasons. common issue broken lid switch
Posted on Nov 13, 2008
  • Ron Coons
    Ron Coons Nov 13, 2008
    no probly not, buzzing sounds can be something in pump, possible bad motor, if you can try undoing the pump assy(atleast take off hoses leading to it adn ck for debris), "'belt is fine"??? thinking if this is a thin twin washer has no belt ,uses a motor coupling.
The water in my stackable washer and dryer wont drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Maytag LSE7806A Top Load Stacked...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Whirlpool thintwin stackable unit
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 25, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool stackable washer
try unplugging from the power and starting again
Jul 30, 2008 | LG WM2077CW Laundry XL Front Load...
Whirlpool ThinTwin
have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
