Question about GE Refrigerators
LITTLE OR NO WATER IN ICEMAKER TRAY
We just replaced both water valves along with the water filter and can't see any water coming down the tube to the ice tray, but we do now have water coming out when the water button is pushed. There was air coming out at first but then it cleared and the water now flows from the water side but we can't see any water flowing down through the fill tube in freezer at the ice tray.
    Problem Solver:
  • 18 Answers
Is the ice maker fill tube frozen? What is your model # ? Is there water leaking on the floor? you may have a broken or cracked hose at or around the water valve
Posted on Nov 15, 2008
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Frigidaire icemaker still overflowing after replacing inlet valve
Make sure the water is not splashing out the fill tube rather than the icemaker. Sometimes ice forms in this tube and causes the water to shoot over the tube and run down. You could also try turning the water faucet valve down a bit. Your water pressure could be too high and it is filling too fast. Last thing if you have very hard water the cubs could be sticking in the mold tray and not releasing. When the icemaker fills again there is still ice in ther causing the icemaker to overflow.
May 17, 2014 | Refrigerators
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
My Amana icemaker is not working well. Water comes into the big tray and freezes, so the mechanism can not dispense the ice. I tried replacing the entire ice maker unit but the problem is still there. ...
couple things to check is the fill tube to the icemaker make sure it is clear and free of any ice... sometimes the water will come in and spray in rather that freely flow...this will cause ice to form where you don;t want it... second thing is yes the filter could be a problem... 3rd thing to check is the water valve itself may not be shutting off all the way or not running as much as it should...
Dec 31, 2010 | Amana Refrigerators
Icemaker won't fill tray,
Was the inlet tube frozen. If so your water inlet valve on the back where the water supply comes in is probably leaking and when the water reaches the freezer it freezes, blocking the inlet tube. Replace the water inlet valve.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Samsung RS2630WW Side by Side Refrigerator
Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the...
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Feb 18, 2009 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid Icemaker does nothing. Ref. Mod.kscs25Inssoo
This also happened after I changed the water filter. The small black rubber tube that fills the tray was plugged with ice. Instead of hot wash cloths I used a hair drier for a couple of minutes.
Jan 14, 2009 | KitchenAid Superba Architect KSCS25INSS...
U-line ice maker water never shuts off
It's supposed to run down the little gray stand pipe and down the tube to the drain. But, if it's going over the side them the unit is probably not level or there's too much water? The tray migh have warped a little? The exact model number would help me diagnose.
May 13, 2008 | U-Line Icemaker
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
