Question about NEC MultiSync FE1250 22" CRT Monitor
FE1250 Horizonal collapses after 10 minutes
My FE1250 (2 years old) was working great until this week. Now after being on for 10 minutes, the picture will collapse about 3 inches in on each side and jumps back & forth at a rate of 2 to 3 times per second. Seems to be heat related as same things happens after a short cool down. Good for 10 minutes, then begins to look like an accordion.
2 Suggested Answers
headstrong
  • 233 Answers
SOURCE: Display Collapse
it is repairable but for the cost of parts and labor you would be better of getting a new 22" LCD monitor
for the problem I would suspect the fly-back transformer or power supply
thanks for rating
Posted on Jan 09, 2008
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
Sound but no picture
U change ur bulbs lately,might need new bulbs.
Sep 22, 2009 | Televison & Video
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
The green is taking over all the color on the tv
March 14, 2009
I have the same TV which had the same issue ( green in picture ) - back on 10/2007. I called Sony. They had their technician replace the optical box ( factory defect ). There was no charge for the repair even though TV was out of first year of warranty. Call Sony.
Sony Repair (866) 282-7412
Mar 12, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Help With My Protron Flat Screen TV
I rebooted the television. Turned it off, unplugged it and disconnected the cabletelevision. I left it that way for about 10 minutes and replugged it all back in and turned it on. It works great now!
Jun 10, 2008 | Protron PLTV-32 Television
Rainbow vertical lines on screen
THAT HAPPENS WHEN IT GETS TOO HOT, MAYBE YOU HAVE TOO MANY THINGS PLUGGED INTO THE SAME OUTLET
Apr 28, 2008 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Display Collapse
thanks for rating
Jan 09, 2008 | NEC MultiSync FE1250 22" CRT Monitor
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
NEC MultiSync FE1250 22" CRT Monitor Logo
98 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
