When I turn on the receiver it only stays on for a few seconds, it then shuts itself down.
4 Other Users Have The Same Problem
Comment by drapadew, posted on Jun 30, 2008
Have the same problem
Receiver turns on for a few seconds and then shuts down.
Seems like there are a few of us with exactly the same problem
Comment by nospamnyc, posted on Feb 17, 2008
Same problem just encountered here. Unit shuts down with a relay-like "click". Turning it back on, I hear click then a second click, then shuts down into standby mode.
Comment by lonalwest, posted on Jan 10, 2008
I have the same model and I'm having the same problem. I took it to a JVC authorized repair shop and they qoted me $350 without even looking at it. That's more than it cost new. Can this repair cost be right?
Comment by Guest, posted on Nov 19, 2007
turn on my J V C RX9010V receiver but it shuts off right after it's turned on and can not find out why. would appreciate it if you notify me that is if a solution is offered thanks Darryl
The repair cost for this type of problem is normally about $125 to $150 depending on just how much damage has been done to the bad channel. It can be different in every case, but normally it is just a couple of output transistors, a few resistors, and then a couple of driver transistors. The parts are the least of the exspense, the labor is what costs the most. These are very high tech pieces of equipment and can not be repaired by laymen without the proper training.
Nobody can tell what is the exact problem without at least going inside and checking it out first. The shop one of you took it to and they quoted you $350 for the repair without looking at it is because they must offer free estimates. They must be able to cover almost any situation that could be the problem and still keep within the estimate. Most of the really good shops will charge a fee for an estimate and that way you find out what is really wrong with it. No shop wants to work for free, so if you get a free estimate, you are really only getting a free "guess". Sometimes it takes an hour or so to just be certain of the damage to a unit. You can not do that kind of work for free and stay in business.
Let me know if any of you require any more help.
Dave
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for JVC RX-9010V 5.1 Channels Receiver
Email this problem
Can you Help with these Receivers problems?
Automatic JVC Shut-Off
JVC receiver shows power, but...
