Question about Gateway 310 S PC Desktop
Monitors wont work
Whenever I turn my computer on no matter what monitor I have hooked up it will just say check signal cable. And a red light pops on on my motherboard. Any ideas? I have a Gateway Desktop model 310.
  • Gateway Master
  • 32,281 Answers
It appears that you have a faulty graphics card.
If the graphics card is integrated with the motherboard then it cannot be repaired. Just purchase a new AGP graphics card, insert it into the AGP slot and connect your monitor to this card.
You may need to go to the BIOS setup to disable the on-board graphics card.
If you don't have an integrated graphics card, then buy a replacement graphics card.
You will need to install the new graphics drivers after installing the graphics card.
Posted on Nov 13, 2008
How to fix no signal cable on laptop
Select Fn+ F4 (check 2 monitors) for check the change monitor . if not fix press with out FN.
if not fix go to display resolution and select dual display and duplicate .also select video dislpy LCD or VGA out to Both.
use user manual to more info
Oct 07, 2015 | Samsung Computers & Internet
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Monitor wont turn on help
Hello there, first thing you should do is to check the power cable.You can do that by changing it with PC power supply cable .It is the same. If it turns to be OK then disconnect the VGA cable from monitor and then try to power monitor on.There should be an activity on front power LED. If the power LED is not showing any light at all, then do not go further the unit is not working .Else the power led should blink a couple of times then a window pop up scrolling on the lcd saying :" no video signal" so the unit is OK ..Hope this helps. Cheers.
Dec 05, 2013 | LG FLATRON L1919S-SF 19 inch LCD Monitor
Red light on computer monitor, black screen, but nothing else
if the power indicator light from green then turn to red with no display, check the power supply board which may have leak or bulged capacitors. check also weather your vga cable is good, if no signal the monitor will turn to off.
Oct 14, 2012 | Computers & Internet
My computer is on.. but my screen wont turn on . The red light on the botton of screen is blinking and it says DIGITAL POWER SAVING MODE on the screen. how do i make my monitor work ! (:
When the monitor detects no input "signal", it goes to "sleep", to consume less power.
Check that the "data" cable is securely connected to both the monitor and the VGA-output on the back of your computer.
Or, try connecting the monitor to a different computer, to see if the monitor works at all.
Or, try connecting a different monitor to your computer, to see if your computer's video-card is working correctly.
Oct 24, 2010 | LG Computers & Internet
My omnitech monitor is turning red when it wants to. no certain program just whenever
Colours on the screen are generated by "mixing" the 3 primary colours.
Of the primary colours is RED.
So, your LCD monitor is not receiving signals from your computer,
specifying the other two primary colours.
Check the data-cable between your computer and your monitor,
to ensure that the connections are tight at both ends.
Try a different data-cable.
Try your monitor on a different computer, with two different data-cables.
Try a different monitor on your computer.
It could be the video-card inside your computer is failing to "send" one or two of the primary colours.
Dec 31, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
ACER AL1716 - no signal Whenever i turn my monitor on i get the no signal message. Why is this?
make sure the monitor is turned on, if yes check the signal cable of your monitor
Dec 21, 2009 | Acer Computers & Internet
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
May 04, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Gateway 310 S PC Desktop Logo
197 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
