-   Bought it yesterday. Never got it working. Took it back to The Source store. Worked on one computer, but not the other. Brought it home and tried again, but no luck-   trenner
Apr 17, 2009
-   Same exact thing. Lights are working both on USB and mouse. If i switch to my laptop it works fine
-   Guest
Dec 26, 2008
-   I am having the same exact problem. I've had this mouse for only a couple months now and it was working fine.
-   kyledylancon
Nov 20, 2008
-   My mouse has the red light on, battery is good, the usb transmitter/reciever green light comes on when I push the little button on buttom, but goes off when I let go,. It was working fine for a long time, what is wrong?-   pattymae2
Did you try
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it to
Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
try changing the battery to the mouse. my brother suggested this to me and I thought it was a dumb idea because the batter in my mouse was working fine. well...low and behold, changing the battery worked.
Changed the batteries, cleaned the underside of any dust, receiver next to mouse with green light...
(More)
Changed the batteries, cleaned the underside of any dust, receiver next to mouse with green light on. Not connecting into files without double clicking, sems as if frozen at times
Is there anything that wears out or goes dead in the Receiver? Can't get the receiver to light or my...
(More)
Is there anything that wears out or goes dead in the Receiver? Can't get the receiver to light or my computer to regconize it. Do I need the installation CD for it to work? I was told it was Plug-n-Play. NOT.
It was working great. Now when I take the little USB thing out of the bottom, the red light goes off...
(More)
It was working great. Now when I take the little USB thing out of the bottom, the red light goes off instead of on. When the USB thing is attached halfway, the light stays on, but when I remove it completely to plug it into my computer, the red light goes off. I have tried changing batteries, but it doesn't seem to help.
