Question about Lexmark X5495 Printer
Changed color cartridge and getting error
I ran out of color and bought a new one (lexmark color 29). I installed it and now i'm getting an error that reads "Alignment problem, (1) remove tape from cartidge (2) check paper (3) press check mark to try again"
1. the tape has been removed
2. I removed the paper and put it back
3. I've tryed numerous amounts of times and it's still doing the same.
I really need to get this fixed. Please help.
Pull out both cartriges and clean ink ports with water and finger dry with towl Dont be gentle.
Posted on Apr 06, 2010
I have the same problem, but get this: I just installed a new black cartridge a month ago and a new color cartridge 2 days ago and the unit is registering "Empty" for the black & only half full for the color. I haven't printed more than 100 copies on the black or 20 on the color. There is something terribly wrong. The introductory (partially full) cartridges lasted 6 months.
GB
Posted on Jan 29, 2009
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Posted on Nov 13, 2008
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Cartridge Error message on our Lexmark X5150
    The Lexmark machines are designed to kick out anything it suspects may be refilled. If your old cartridge has bad print nozzles this may be tripping the error. Printers are typically for sensitive with their color cartridges anyway because the manufacturers make more money on the color ones. You can try looking around the settings on the machine and in the printer preferences to see if you can tell it to ignore the ink levels and see if you can continue to print.
    Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    Color cartridge missing
    You may want to remove the power brick at the back of your printer, wait a few seconds and reinsert back. Then try the steps listed in the user guide to install new carts, page 42.
    http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
    Jun 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
    Color Cartridge Has Stopped Working...Lexmark Z45 Printer
    i think this a firmware issue of the printer..
    try to flash a new compatible firmware .
    May 12, 2009 | Lexmark Color Z45 InkJet
    Lexmark cartridges
    According to the Lexmark Website, those are the correct cartridges. Did you compare them to the cartridges you removed? Did you remove the tape from the heads? Did you insert them properly?
    Jan 05, 2009 | Lexmark X2500 All-In-One Printer
    I installed a new "genuine" Lexmark color ink cartridge, but it doesn't work.
    then get it replaced by lexmark as the cartridges comes with one year warranty..
    Apr 24, 2008 | Lexmark X5470 All-In-One InkJet Printer
    Lexmark x2500
    Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
    Mar 25, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X5495 Printer Logo
    406 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
