Question about Foxconn 761GXK8MBRS AMD Athlon 64/Athlon 64 FX, Socket 939 (939-pin), 1600/2000MT/s SiS761GX + 965L... Motherboard
Green light is on and but no picture
When i boot it up there is no picture at all just before i did this though i tryed to over clock the cpu but now i can even get the boot screen up i tryed unpluging everything but the motherboard(even the fan) and still nothin happens plz help the pieces are not old i got them only yesterday sooo...
    Scholar:
  • 91 Answers
First, clear the CMOS. Then open the processor from its socket and reinsert it properly.Connect the heat sink. Then start up ur pc. If there is any display then enter into bios by pressing Del.
If there is no diplay, then probably you need to chage your CPU
Posted on Nov 23, 2008
  • 3 Answers
It's a good solution but for reset the CMOS you need to change the yellow jumper J7J3 to 2-3 position (configure). After the POST runs, setup runs automatically. The maintenancee menu is displayed. Put all defaults values, save and exit (yes for save). Turn off it, put the jumper J7J3 at it original position, turn on and enjoy.
Posted on Jan 25, 2007
I had this porblem and it turned out my CPU was failing. check into that.
Posted on Jan 13, 2007
Restart your pc get into your bios and set it back to failsafe mode
Posted on Jan 05, 2007
I have the same issue, except I have tracked one possible cause down to a missing diode (1mm long, rectangular, brown with solder on both ends) which has fallen off of the motherboard at gate C5E5, right above the PCI-X 64/133 riser. I need to find a repair shop that has the tools and experience to re-solder this little bastard and get my server running again! Any suggestions? If so, call Nathan at 949-315-5605 or email me at nduke@phoenixlending.net Thanks!
  • 624 Answers
Yep, this board does in fact have CPU thermal protection built-in. If you have reset the BIOS to the manufactures default values and you are hear or see nothing from the PC when you start and it doesn?t work then is would seem logical that something is wrong with the processor. Just to be sure I would verify that the power supply is in fact working correctly, that all the power connectors to the motherboard are plugged in correctly and the motherboard is grounded correctly. I know you didn?t mention having messed with any of this but it won?t hurt just to make sure especially since the next step is going to probably cost you some money. It is possible that the motherboard sensor was faulty and signaled a shutdown too late to protect the processor. It is also possible that the processor, even though rated at a higher operating temperature failed at something lower. It?s rare but it does happen enough to that the military requires its manufacturers use mil-spec components that have to pass a rigorous operating temperature cycling test. After verifying the basics I would look to the processor or perhaps a close-by component on the motherboard as the source of your problem.
Posted on Jan 02, 2007
  • 4 Answers
Most motherboards nowadays have a thermal shut down it should have shut itself down when it got to hot let it sit for a while see what happens it may reset itself.
    President:
  • 2,961 Answers
If it's a decent board it would shut down your pc before frying the processor. Can you give any more clues eg. beeps if any, is it a new board that came with the processor, is your memory working, try one stick at a time if you have two,is this type of processor needing a seperate power supply connected from your PSU to the motherboard(come across that one before!) other than just motherboard powered.
When i did that before i had to push the reset button.. it would then reboot with the new settings. i found this annoying because u had to do it everytime if i used any overclocking
Posted on Dec 14, 2006
    President:
  • 2,961 Answers
The cmos jumper to look for is called JBAT1, it will be positioned on pins 1-2, so move to pins 3-4, then back to 1-2 and hopefully your processor would have shut itself off before overheating. Re-boot pc and re-set bios time etc.
Posted on Dec 07, 2006
  • andrew pester
    andrew pester Dec 07, 2006
    Sorry I meant to say the jumper will be on pins 1-2, put it on pins 2-3 (not 3-4), there are'nt 4 pins, then back on pins 1-2
I have 3 of the same boards laying around and have had the same problem.Luckily i have extra video cards too. I had to go into the BIOS and "enable" the video chip on the board. If it isnt enabled the board bypasses the chip and sends the signal to the PCI slots. Hope it helps,im not a computer pro but have a little bit of knowledge with this board.
Cpu boot problem no dispaly no beep only power green light on
Try to get other power Supply, disconnect the old one (no need to dismount it right now) and connect the new one. I think the problem could be on it.
Apr 01, 2013 | Computers & Internet
The last led light blinks green and sometimes it turns solid red
red light is stands for hardware boot and the green one is stands for system boot and disc boot. when red light remains solid it means your system is in 0% cpu usage and nothing doing, stop working
May 09, 2010 | Intel SC5299BRP
I cant boot up my acer aspire 8000 , only shows a " going to sleep " sign after i try to boot it up
Check if the CPU is connected to the monitor. also check if you find the power light is steady green on the tower. And their should be a green light at the back of the tower
Dec 13, 2009 | Acer Aspire 8000 (91.5A525.U33) PC Desktop
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
I have a dl 380 g4 it powers up, the hard drive lights come on. I get all green lights no amber. I get no video and the keyboard lights do not come on. It acts as though it does not POST. I have swapped...
Unfortunately, this is most likely a bad system board. Have you tried to RDP or telnet to the machine after it boots? That is, assuming you have some form of remote access enable of course.
Jul 10, 2009 | HP ProLiant DL380 G4 Server
I have a Dell Dimension 4600 and it won't boot up. When I turn it on the green power light comes on and hard drive activity light flashes however no fans come on, the screen doesn't show the Dell logo or...
i would have to disagree with jerry, while that seems reasonable if the motherboard fan isn't running at all then whether or not the video card is ok is somewhat irrelevant.
I would agree somewhat though, i think the PSU might be a good thing to check to see if it is functional.
when you power it on does the CPU fan start or shudder at least ? that would be my first guess for a problem if you had been having any problems recently
Apr 17, 2009 | Dell Dimension 4600 PC Desktop
Won't turn on blinking red where green power lights should be.
plase open the cpu & plug in the ram in the right order.
Dec 10, 2008 | HP Compaq d530 PC Desktop
Asus P4S800-MX Motherboard video problem
The system speaker is usually a set of four pins and you use the outside pair to connect the speaker. You may need to go to the Asus web site to download the manual if you don't have it. Try to reset the bios either by shorting the appropriate pins or by removing the battery for a while.
Sep 06, 2007 | Computers & Internet
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Foxconn 761GXK8MBRS AMD Athlon 64/Athlon 64 FX, Socket 939 (939-pin), 1600/2000MT/s SiS761GX + 965L... Motherboard Logo
174 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
WTF Chuck.....
WTF Chuck.....
Joe Negus
Joe Negus
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
