Volume control knob is damaged inside ,try to put 3drops of
kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
www.stangnet.com > ... > SN95 4.6L Mustang Tech Nov 16, 2010 - Last night on my way home from work something broke in my engine. I have a 98 GT. It sounds like it's coming from the top of the passenger ...
? 0:11 https://www.youtube.com/watch?v=IMp1H8-0BSE
Aug 9, 2013 - Uploaded by team14robot
Freeing up a stuck valve without having to tear the engine down - Duration: 11:38. by dawino6260 47,255 ... 2005 scion tc enginetap/knock.
it goes up to 31... while u are in the music section, tap 'vol'... this should cause your the red 'vol' on the screen to start blinking... while its blinking tap '<< to volume down, and tap >>' to volume up.... when its where u want it, tap vol again to stop it from blinking...
I have a Korg C-15s and also experiencing loud crackling sounds when I turn it on. The problems seems to be either the sliding volume control or the amplifier itself. Honestly though, I believe the issue is the volume control. I opened my piano to get a closer look and attempted to clean the contacts on the volume. Unfortunately after cleaning the contacts, the crackling sounds became somewhat worse. After I turn the piano on, the volume control is generally rendered useless......volume set to low volume and the noise is quite loud and other times the volume control is set high and get very low volume crackling noise. No real consistency. The noise does diminish after a few minutes but so does the piano sounds to an inaudible level. There were a couple of instances where I turned it on and surprising enough, no no noise and perfect sound. For these reasons I believe the issue is within the volume control and not so much the amplifier. I have an electronics background and noticed that the volume control is very unique in design and is not something that can be substituted with another volume control from other sources.
My recommendation is to check the sound quality of the audio from the RCA L/R audio outs on rear of the piano by connecting to a stereo receiver. If it sounds fine you're in luck. If the crackling sound does not diminish after a few minutes like mine does, I would suggest disconnecting the internal speakers and using the audio out only. You can connect a pair of studio monitors or high quality computer speakers, preferably with a small subwoofer to deliver the full audio range and deeper tone of a real piano. I'm currently using a basic pair of Logitech computer speakers and is quite acceptable until I can afford a high quality set of monitors or relocate my piano closer to my high quality Yamaha receiver.
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Hi.... ONe of the leads on the CD cable has a broken ground (thats why it hums loud) The speaker that has only the tweeter working: The woofer is blown in the speakers. Check also for good solid wire connections at both ends of your speaker cables
That is actually not really a problem mine does the same thing you just have to tap the button let it go and keep tapping till you get to the acciured volume. You cant hold it down or it will take off and get loud fast i leaned that when i first bought it. Hope this helps.
