150000 1974 national gas forced air furnance does the fan come on the same time the gas comes on. model no. g-u 313150-16m
  • wildbillcurr Nov 16, 2008
    thank you for the comments.  i see a spring and will try to fix my furnace with the advice i got from this site, thank you
    Novelist:
  • 124 Answers
Not familiar with that particular model but on virtually every type and style of furnace i have worked on in the last 21 years. the fan is delayed. usually the burner lights then 3 to 5 minutes later after the heat exchanger has gotten nice and hot the fan comes on and blows nice and hot air. on old furnaces there was and is a switch usually on the upper right side of the furnace bulkhead that has a spring like device that heats up and rotates till it makes a set of contacts that turn the fan on. if it gets to hot the set of contacts breaks the power to the gas valve and shuts down the burner. as the furnace cools down on shut off there is a third set of contacts that open to turn off the fan so you don't get a draft. sometimes the stat can be wired up wrong, and it will bring the fan on right away ,and air will be cool and drafty till furnace catches up.
Posted on Nov 13, 2008
MY FURNACE MAKES A HUMMING SOUND WHEN IT COMES ON
Could be gas valve when energized
Make sure filter is clean,plugged filter will increase amp draw on MTR.
Jun 09, 2014 | Coleman Propane Forced Air Heater...
Bryant furnace
Check gas valve is not on pilot only check air filter is clean check connections to gas valve .
Oct 10, 2017 | Heating & Cooling
GAS FURNANCE NOT KICKING ON HEAT CAPF024A2A
Do you know if they purged the gas lines? Sometimes when the meters are changed air can build up in the gas line
Dec 07, 2012 | Heating & Cooling
Gas furnance lights but fan does not come on. buzzing sound from panel near fan.fan is not jammed it spins freely.unit is seven years old.
Most furnaces equipped with an electronic control board activate the same blower speed for heating and continuous fan. If the cooling speed works, the problem is likely in the circuit board (relay) or wiring to the motor. Check and rectify.
Jan 11, 2011 | American Standard Heating & Cooling
Fan in furnance
any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Jan 24, 2009 | Coleman Propane Forced Air Heater...
Hello my name is veronacarrier 8000 weathermaker will not ignite
call the furnace repairman. you have a fairly easy repair but the parts are expensive
Dec 13, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
161 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
