Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Plastic in ice
I have plastic in our crushed ice
  • dlduk Nov 13, 2008
    my issues is the fridge is only two months old and i have had he auger changed and the fridge which is a week only and still finding plastic in the crushed ice wonder if manufactor defect.
    President:
  • Frigidaire Master
  • 2,651 Answers
Umm thats not good. reomve the ive bucket fro mte hfreezer and empty ice, ill assume that the bucket/cam / auger assy is cracking and alllowing broken plasctic to enter .you can order a complete ice container w/alll moving part. manufactur elists part for about $120.
Posted on Nov 13, 2008
  • Ron Coons
    Ron Coons Nov 14, 2008
    place another call to the manufacture. the auger motor wouldnt cause plastic, but the auger itself, passing the ice throughthe front of container/chopper blades
Ice dispenser stuck on crush
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
There is a lever arm on the back of your ice bucket. This arm goes into a opening behind the ice bucket. There is a plastic actuator that raises or lowers to set the dispenser to either crushed or cubed ice.
So, you either have a broken plastic actuator or a bad operating solenoid valve. Both of these components are easily replaced.
Send me your model number which is on the upper inside wall of your fresh food section and I will give you the part numbers of these components.
May 08, 2015 | Refrigerators
Trouble with crushed ice function on ge profile fridge
Replace the bin. I think if you inspect it, you will find some plastic broke off of it.
Aug 18, 2012 | GE Refrigerators
Ice cube dispenser will only deliver crushed ice
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
Apr 02, 2010 | GE GSS20IEP Side by Side Refrigerator
Ice cube are not dipensed only crushed ice
I had the same problem you do - the solenoid that lifts that white plastic piece is dead. But I also rent the place where I live, and it comes with the fridge. It's not likely the landlord will want to deal with this issue since I can still get ice, not considered a necessity, etc. So here's what I did to make it so that I always get cubed ice.
I only get crushed ice even when the button is on
Pull the ice bin out and you'll see a rectangular hole with a plastic piece that has a rectangular hole in it. This piece will correspond to a steel rod that runs along the bottom of the ice bin. This steel rod actuates the crush/cube option in the dispenser. Sometimes icing can cause the plastic piece to get stuck. Try "jiggling" the plastic piece up and down until it frees and operates easily. Then replace your ice bin and try operating the controls on the dispenser again.
Dec 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
May 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cubes are not crushing
take out the auger assembly (plastic pan with metal coil in it) and dump out the ice and clean and defrost it. let it dry before returning it to the freezer. sometimes ice will buildup and cause this problem.
Jul 10, 2008 | Frigidaire Refrigerators
No crushed ice
  • pull out the auger assembly (big plastic tray with a metal coil in it that holds the ice) and dump all the ice out.
  •  clean out the whole thing and let any ice residue melt, then try it.
  • sometimes a small amount of ice will buildup around the ice crusher and keep it from engaging.
Jun 29, 2008 | Frigidaire FRS26KF5C Side by Side...
Ice crusher has stopped crushing
There is a little bar that is on the ice bucket. That bar has to go into the middle of the plastic square that is on the back wall of the freezer. Try Pulling out the ice bucket, get a hair dryer and run the hair dryer on the back wall of the freezer right above the hole where that little bar goes. After you run the hair dryer for about 10 minutes or so put your finger in the hole and pull down on the plastic square. Make sure when you put the ice bucket back in the freezer, the bar goes inside the square hole, not under it, not over it. In it. If that doesn't fix the problem you probably just need a new solenoid. Part number 5304404333
Let me know how you make out. Good Luck
Bill
Jan 13, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
