Question about Canon PIXMA MP180 All-In-One InkJet Printer
Pink ink not coming out
Our ink isn't coming out of our Pixma but its a new cartridge. I have deep cleaned the printera number of times but it isn't changing
  • Canon Master
  • 4,338 Answers
This seems to be a common problem with Canon Pixma printers. Here is a web site with great info and instructions on how to cleand the nozzles on the prinhead:
http://www.inkjethelper.com/inkjetstuff3.html
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 13, 2008
I have cleaned and deep cleaned the printer a number of times but when I do a print check the yellow line does not print neither does the black line under it print. When I print anything else the yellow...
If a line doesn't print, the ink is out of the cartridge for that inkjet cartridge color. Replace the cartridge. Deep cleaning can use a lot of ink up at a time.
Nov 11, 2010 | Canon Pixma iP4500 InkJet Printer
Pink and blue streaks on right side of page
most probably your "soak" pad need exchange. check your manual and change it. when you "deep clean" heaps of ink is absorbed into the pad exacerbating the problem, not solving it.
remove cartridges first and check them for existence of any foreign matter,
check for presence of debris under the head and parking place, remove if any,
i would suggest cleaning of printheads, albeit this can be risky (check first if your ink is soluble in water, isopropyl alcohol or methylated spirit, use that which solve your ink without clumping as cleaning agent), remove cartridges and allow appriopriate solvent to sit few second on metal rasters, wipe them with clean absorbing tissue and repeat procedure till solvent is "sinking" through the net.
remove old and install new absorbent pad under the print heads,
re-install inks, print rest page and then "normal" page. ink on first test page maybe very weak as solvent need to go through first.
if you follow the steps correctly, your should have clean print on the end.
"deep cleaning" is just waste of time, effort and ink. it is better if you create yourself a document with alternative lines of all three basic colours and black and then print it.
Jul 26, 2010 | Canon PIXMA MP780 All-In-One InkJet...
All of the ink cartridges are full, but the printing comes out very pink.
do the deep head cleaning for few times, it will drain some amount of ink but should work. After each cleaning check the printed nozzle pattern.
PS head cleaning is under printer properties-maintenance.
hope that helped
Jul 13, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
E 5 problem printera canon210
Hello, Anita.
E5 is usually referring to a cartridge problem.
First, clean the contacts:
(1) Open the printer
(2) Remove the color ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
Your cartridge could be faulty and need replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA® MP210 Printer
Blue ink turning pink?
Ah! But did you put it the right place? It's sounds like it could be a leak on the cartridge though otherwise.
Feb 11, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Colour printing suddenly dominated by red/pink hue. All ink tanks in order
It sounds like you are using aftermarket or refilled cartridges. To clear the sensors and nozzle, install new OEM cartridges, run deep cleaning a number of times (at least 3 times), and then the alignment utility.
Aftermarket/refilled cartridges do not always meet the manufacturer's specifications for quality. Try cartridges from LDproducts.com for your printer. I've never had a problem with their aftermarket cartridges.
Please rate this solution. Thanks.
Dec 13, 2009 | Canon PIXMA MX7600 Multifunction inkjet
Canon pixma ip4300 - magenta ink is recognized but not printing
Take the print head out of the machine and sit it in a saucer of very hot ( just off boil) water about 10mm deep for a minute. Take it out and sit in on a pad of paper towel to dry briefly before returning it and the cartridges into the machine. Give it a deep clean and try again. If still no good, the print head has probably had it.
Oct 24, 2017 | Canon PIXMA iP4300 InkJet Photo Printer
Exactly the same problem
You might like to try purchasing a new Ink cartridge Carriage after Deep Head Cleaning 4 - 6 times. Sometimes it takes this number of times to clean the Cartridge Heads.
This has worked for me on a IP4000 Pixma.
Warm Regards
Bill Held
Jun 21, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer is printing everything in pink
more details please:
manufacturer
model number
if it's an inkjet, run any maintenance procedures like cleaning heads, take out each cartridge, take paper towel wet with warm water and touch nozzles gently to remove any dried ink.
Apr 07, 2008 | Canon Pixma MP950 All-In-One InkJet...
Im so confused
Pink? Relate the cartridge colours to us on here
Jun 03, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Open Questions:
See all Canon PIXMA MP180 All-In-One InkJet Printer Questions
Canon PIXMA  MP180 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
