Question about Miele Dishwashers
Miele G527 dishwasher about 23 years old. Motor makes an unusual noise , sometimes lowder than others. Occasionally it trips the earth leakage proytection switch.
  • 196 Answers
Open the device and check if any thing blocking the motor.
Posted on Nov 12, 2008
  • 2 more comments
  • mmechanics Nov 12, 2008
    may be it needs the unit is very much old.
    also Have a look to make sure something has not fallen into the pump assembly, sometimes a hard piece ( like a pit ) or small utensil can fall into the pump and make a grinding style of a noise.
    One of the most common question that I get on a dishwasher repair is "how does that motor and pump impellor screw come out?"
    Inside many dishwasher pump assemblies is a screw that goes through the upper impellor and screws directly into the motor shaft. Since the motor shaft and screw are made of guessed it...they can / will rust. The screw can rust and become very tight and difficult to remove!! These screws are normally a right ( regular ) hand thread, socket or nut driver can be used to remove the screw. One hard thing to do is to hold the impellor still so the screw can be removed, they often just turn together. The impellor may be jammed with a screwdriver to hold it still so the screw can be removed...sometimes the impellor can be help still by placing a rag on it and hold tight with your hand, the rag will help prevent a sharp edge on the impellor from cutting your fingers. The odd time that screw is too rusted into place, soaking a little rust buster or 3in1 oil on it over night may help loosen it. Sometimes trying to tighten the screw a little at first will help break it free. There are some tool ( see below ) that can be purchased to help hold the impellor still so the screw can be removed, these are only for a few models and pump assembly styles.
    WLP seal tool helps center and install the pump seal
    impellor remover and install tool
    Once the screw is removed, the next obstacle is the impellor can also get stuck onto the motor shaft. Many times I have to break off the old impellor. A sharp blow straight down with a hammer and flat screwdriver will often crack the plastic impellor...careful not to damage the pump body! If the motor shaft has indeed rusted, clean it up really good with sand cloth.
    also check out this link
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
I have a built in Miele Nespresso coffee machine that shuts down (and trips the fuse board in the house) just as it has dispensed coffee. Anyone any idea what is causing this? Thanks
some liquid is leaking into the electronics or there is a motor gone
or some other leakage to earth of electricity
as i say can be liquid or a motor or a heating element
i think your model heats the milk so i presume some element has failed
its a job for the local approved service or see where you bought it
Jan 10, 2015 | Miele Coffee Makers & Espresso Machines
Can't find manual for Miele Dishwasher g527
go to or www.retrevo.comGod bless you
Apr 02, 2013 | Miele Dishwashers
Esl624 tripping fuse even when off
Hi. Your dishwasher has probably a leak on the pressure side of the circulation and spraying water over all the electrics including the mains filter. this will trip the electrics without being switched on. It needs to dry out and the leak fixeded. check the hose from the cartridge heater to the top spray arm hose. You will need someone with insulation teater to test all components for earth leakage. good look.
Aug 04, 2012 | Electrolux 23 in. ESI602X Built-in...
My AEG dishwasher has just broken down according to the repairman who came out to fix it. He has offered to sell me a 12-year-old reconditioned G527 Miele with 1 year warranty. Should I buy it? ...
Well ok, you can find a new AEG for $1,200.00 and up
2nd you are correct the D3553 is a older model. you can buy a new one, at a lower price...
Now the G527 for 700.00. might be a ok price. with a 1 year warranty. take a look at it, and see if its, nice looking. before its installed. and look at the lower insides. and see if you see rust, etc
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Miele Premier-Plus Built-in Dishwasher
My Miele Inspira has started squeaking when it runs.
Hi dear.It sounds like your machine have faulty bearing on main wash pump.That bearing can worn out it self or there is a leakage on impeller housing,that leakage can cause harsh chemical to get in to the front bearing of motor & damage it.Your machine should be under warranty,call Miele service in your country.I hope that helps.Thanks.
Jun 20, 2010 | Miele Inspira G2180SF Stainless Steel...
I have a aeg 43070 vi dishwasher It keeps tripping the circit breaker on the house fuse box . I have reset the leak cutout by dipping the dishwasher back and stopped the warning sound,but went for about a...
I assume you are refering to the earth leakage circuit breaker. This trips when a earth leak fault has occured. The normal cause for this could be
A) Water leaking via a pipe at the bottom comming in contact with one of the electric motors at the base of the washer.
B) A heating element has gone faulty with a electrical leak to earth.
You need to test this with a multimeter on the OHMS scale and rectify any short to earth that the meter would indicate.
Mar 21, 2010 | AEG 23 in. Favorit 44070Vi Built-in...
Instruction manual for miele G527 dishwaser
You will find most manuals on the miele website. Go to Customer service then technical service. Then operating instructions.
Mar 10, 2010 | Miele Premier-Plus Built-in Dishwasher
Hi, My Miele G527 dishwasher is tripping the circuit breaker
I would suggest that you get in an electrician to test the washing machine for shorts and insulation problems as it could be shorting out in the motor or ground leakage from failing insulation
Apr 25, 2017 | Dishwashers
Dishwashers Logo
190 people viewed this question
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
