Question about Akai PT4298HD Rear Projection Television
Faint diagonal lines in t.v.
I have an Akai pt4298hd that I aquired a short time ago that a 3 year old sprayed cleaning fluid on. It burned a hole in the red crt board. I replaced all the boards as a unit and the t.v. is up and running. The picture and colors are sharp, however, there are faint diagonal lines that will come and go in what seems to be a clockwise pattern. They seem to cycle about every 1-2 minutes. I do not believe the problem lies in the crt board adjustments because anything I do, including going to just black and white, there is no change. I thought it might be some sort of reception problem, but no change through a dvd player, different cables, etc. Everything looks great except for these annoying lines. Does this sound like a bad component? Any help is appreciated.
  • Stephen Johnson Nov 29, 2006
    I had a shop look at it and it is definitely mot a convergence issue. I am getting some sort of interference or frequency problem. It duplicated the problem identically at the shop, but they could not locate the problem. I don't know how much time he actually spent to evaluate the problem but it was a free checkout and he said he couldn't locate it. I could take it to another shop, but I don't want to get into diagnosis fees if I don't have to. Any input will be appreciated.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
Try turning down screen controls. turn up until you see the lines and then back off until they dissappear...easy as that! john
Posted on Sep 12, 2007
What is the 2002 olds alero(2.2 Litre with the 4t40) transmission fluid capacity after changing the transmission out completly. I am talking the torque converter and the pan+filter. Full Service. thanks...
It should hold between 10-13 qts It all depends on how big of cooler you have and if the lines, cooler, and torque converter are completely drained. Heres a tip before you start the car take the tranny lines off the tranny and take a 6'(it dont have to be exactly 6") long rubber hose that fits tight on 1 of the tranny lines. Slide it over the line and clamp it on there, take a pick, nail, screw or anything that will make a small hole. Make a hole in the rubber hose about 2" from the tranny line. Get 1 or 2 cans of brake clean put the straw from the brake clean in the hole you made and put an air blower in the other end of your hose. start spraying the brake clean and the air blower at the same time and keep spraying till it is flowing clear out of the other tranny line. Make sure your flowing through the cooler and not the tranny. By doing this you get all the crappy tranny fluid from the old tranny out of the lines and cooler. Watch your eyes it burns very bad if you get brake clean in them. WEAR GOOGLES OR SAFETY GLASSES!!!! Goodluck, Kyle
Oct 10, 2010 | Oldsmobile Alero Cars & Trucks
Akai pt4298hd 42 inch projection tv has red and green haze.part number stk392-040 were replaced 2 years ago.that fixed the problems.the symptons are the same.are these chips easy to acces ?
Yes they are But CK 2 resistors 2.7ohms in front of ICs if they are Bad they can cause same Problem to order new ICs $9.50 each Call Mats Electronics
1-800-628-1118
Dec 20, 2009 | Akai PT4298HD Rear Projection Television
Akai PT4298HD..Please help!!
Normally, yes.
Make sure you get the CG Board Part number:
BP94-00155A
There are other boards in this set that say convergence, but, they are not the boards you want.
Available at:
Andrewselectronics.com
Easy to replace.
Any questions, reply to this post and I will respond.
Jan 13, 2008 | Akai PT4298HD Rear Projection Television
Big screen tv will not turn on
Problems are in power supply or scanning circuits. Unit is in need of reair. Call in pro/tech
Nov 30, 2007 | Akai PT4298HD Rear Projection Television
Akai PT4298HD displays yellow tint in lower left
OK YOU CANT 'BURN' A REAR PROJECTION BUT THE CONVERGANCE CAN BE GOING OUT BUT I WOULD GUESS THE SIGNAL TELLING THE PROCESSOR - OR THE PROCESSOR ITS SELF- IS PROBLY GOING OUT WHICH MEANS A BOARD NEEDS REPLACING I DONT KNOW WHICH ONE I WOULD GET A PRO TO CHECK IT AND TELL YOU WHICH ONE IT IS THEN ORDER IT ONLINE AND REPLACE IT YOURSELF
Nov 15, 2007 | Akai PT4298HD Rear Projection Television
Set won't come on
FWIW... my Akai PT4298HD just quit also, same symptoms. Just 2 years old. Will continue to search for solution.
Sep 13, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
83 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
