Dell inspiron 1150 screen goes black after standby
Hello. my dell inspiron 1150 screen goes black after i close the lid and it goes in standby. i open it and its just all black. the computer is on and running, but nothing responds. i waited about 10-15 min. and nothing happened. the only thing that worked was that if i used a hard reset, then it went back to normal when it started back up. this happens whenever i close the lid and it goes to standby. i don't know if this helps, but my cpu's hard disk space is 27.9 gb with 21.4 gb used. i also have 1 gb of ram. the only thing i recently did that was out of the ordinary was use the disk defragmenter and disk clean-up like i do every month.
Kiranbala
  • 91 Answers
SOURCE: dell inspiron 1150 screen goes black after standby
Let me help you regarding this, As your notebook is not having low room to handel the standby applications, i suggest you to change the power options in the control pannel. There you find POWER OPTIONS icon click on it and go to advance tab, there u find the option called WHEN YOU CLOSE THE LID, put it to DO NOTHING. So that nothing happens when you close the lid. I hope this helps you. BYE
Posted on Nov 14, 2008
Screen goes black close lid and open screen works fine
what configuration of the power manager do you use? laptop goes to hibernation mode automatically or by pressing the power button or by closing the lid?
Feb 04, 2014 | Dell Inspiron 1420 Laptop
Problem with magnetic switch. Sometimes when I
in the control panel power options chnage the setting to never for sleep options and dim display options
Sep 03, 2013 | Dell Inspiron Computers & Internet
I have a Dell Inspiron 1200. The standby option
Go to the power option and select Laptop power schemes. Restart the computer that should fix the issue.
Thanks
Jul 06, 2010 | Dell Inspiron 1200 Notebook
When i close the lid on my dell inspiron E1505 the screen goes black and when i open it back up it stays black
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Apr 02, 2010 | Dell Inspiron E1505 Notebook
Dell inspiron 6400 i had to reformat and reload all software now when i close my lid and reopen it the screen is black and won't come back on i have to turn off and start up again. all power setting set to...
Machine is going into standby. When you open the lid, press the power button for about two seconds. the machine should come back to full operation and after logging in, you should be back exactly where you left off. I have similar model I am using now to answer your query and I have just done this. No problem. Good Luck, Ian.
Jan 13, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Oct 01, 2009 | Dell Inspiron 1300 Notebook
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Goes into standby when I OPEN lid
ok - if you are using XP -go to your start menu - control panel
click on power options and click on the 'advanced' tab - this will give you the options of what happens when you shut your lid.
if using Vista - click on control panel, choose 'classic view' from the left sidebar and carry on as above
hope this helps 8)
Dec 07, 2008 | Dell Inspiron 1501 Notebook
Nov 14, 2008 | Computers & Internet
Cant open laptop
Is this when you start it up, or after closing the lid and the machine being on standby?
Jun 25, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
158 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
