Tb drive blocked in wrong start up program loop. can still write but can not access. cause it auuthomatically runs wrong prgram.
    Genius:
  • 1,913 Answers
Go to run type "msconfig" then startup then disable all.then appply ok.
then restart.
Posted on Nov 12, 2008
How do I wake a sleeping hard-drive on my pc
possible hard drive failure, try shutting machine on and off consecutively 10 times, to get running.
good luck
Jan 17, 2016 | Seagate Barracuda 7200 1.5 TB 7200RPM SATA...
My computer won't stay running. It keeps shutting off and when I go to start it up it will start to start up and then shut down. If it does start up it makes a loud noise on start up.
Root kit viruses can cause this.this is a boot loop virus that causes a repeated shutdown loop to prevent normal access to operating system.If you can't get into safe mode and run malwarebytes. See if you can download tdskiller or kapersky rescue disk onto a usb stick on another computer. Then on the infected machine change the bios to read from usb first.the flash screen usually tells you to hold or tap f2 or del on most computers to get into bios... But some it is f10 or f12. Google rootkit virus or go to bleepingcomputer.com and follow instructions.These are quite difficult to remove.if all of the above fails see if you can piggyback the hard drive on to a protected machine and scan and clean infected drive.
Feb 17, 2015 | Computers & Internet
PC boots up then screen goes blank
You are asking for trouble by placing programs that Windows uses on the other drive. You are better off using the 1 TB drive as a system drive. Sounds like your OS is corrupted.
Feb 19, 2012 | Dell Dimension 8400 PC Desktop
Continue looping restart, i replace new PSU, memory and hard drive but still looping motherboard Asrock G31M-S DDRII
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jul 21, 2011 | ASUS P5KPL-AM SE Motherboard
WD Software will not load up, and Windows keeps giving me an I/O error. With the I/O error, I am not able to see or access any files that I have on my WD MyPassport 1TB, SN WXD0AA9W6561
Have you tried another USB port.Try not using a USB hub and plug it into a different port on your PC. Also try temporarily disabling your virus and anti-spyware program. My virus program Antivir always blocks my WD software. There may have been an update that now blocks it. Check all your cables and plugs on the WD drive and if still not working try starting your pc in safe mode and see if the WD drive is recognized. Hope this was some help, Thanks for using FixYa
May 11, 2011 | Western Digital My Passport Essential SE...
I have WD 1 TB hard disk portable but when ever i connect to laptop it blocks it from checkpoint security software.Is there any way to unblock it?
my dear ! I'm really happy cuz i hv done it in just 4 to 8 minutes !!
I'm so happy to tell u that ! u should just update ur wd device system system >>>
You can format your Western Digital drive .first you connect your drive with the computer. Now when the drive prompts you for the password then you enter any wrong password five times. Then you will be prompted to erase the existing drive. If it doesn't prompt to unlock the drive then access the Western Digital smart ware Cd and in the unlocker button double click it.I hope this if you follow this solution your problem is over.
I love to help people because I'm MUSLIM :)
Jan 28, 2011 | Western Digital My Passport Essential SE...
Hooked up a Viper 5301 in a 2004 Nissan Murano. The problem I'm facing is that the unit is only programming when the vehicle is started and running, instead of programming after turning the ignition on...
It sounds like you have your ignition and starter wires reversed. The remote start programs when the ignition wire sees 12 volts and then loses the 12 volts. If you have the remote starts igniton wire on the trucks starter wire then that is why you can prgram it when you start it only... cause you get 12 volt only when the truck cranks and then loses the 12 volts once it is runnng. You may have the right colors from the remote starter correct but check to see if maybe from DEI they have the wires in the wrong positions.
Jan 20, 2011 | 5301 Responder LE 2Way Remote Start and...
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Internet
what type of program are you using? check the properties or references of the programs that you are using. you may need to configure it in accordance with your home network setup. your firewall (software or router/hardware) may also be a cause. check your firewall settings and enter the port number being used by the program. make sure that the firewall allows your program to run and connect to the internet.
May 27, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
