Question about Riso RZ220 Duplicator
Riso 3770 Error Code T11
My 3770 stopped in the middle of running a job and displayed error code T11. Any clues on what this is and how to fix it? I already tried the clear codes and that didn't change anything. Also turned the machine off and back on. No change.
Thanks!
Janet
This is a presure motor lock eror . you will have to unplug the potentiomotor on the back of your IO board
Posted on Sep 03, 2009
  • Rita Buff Apr 13, 2011
    Where is the IO board. Thank you
    Problem Solver:
  • 11 Answers
This is a presure motor lock eror . you will have to unplug the potentiomotor on the back of your IO board .
Posted on Dec 01, 2008
Riso graph GR3750 marca falla t11 necesito asesoria para solucionar este problema. O es necesario llamar a soporte tecnico ??
"Risograph GR3750 marks to fault T11. I need consultation to solve this problem. Or it is necessary to call to technical support?"
Error T11 means: Call service.
Here some details of the error which may help to solve it: Pressure Control Motor Lock • In 100ms from turning ON of the pressure control motor, the encoder sensor cannot detect a pulse. • In 5 seconds from turning ON of the pressure control motor, the pressure centering sensor is not turned ON/OFF. • When the fuse of the main power board is gone.
Feb 28, 2011 | Riso RZ220 Duplicator
What is a T11 error code mean on a Risograph GR3750?
this problem is on pressure motor, stay in rear part machine,i don´t remember of the code for testing. after i put here, if you need pass e- mail for luizalexdias@hotmail.com
May 05, 2010 | Riso RZ220 Duplicator
Riso 3770 error code T3
A T3 error code is indication of some kind of problem associated with the clamping mechanism. Most of the time, what happens is that there is a magnet attached to a flag on the rear side of the drum and it has fallen out of place. If you can find the magnet, reattach it with a strong adhesive.
Check for smooth operation of the clamp by hand as well and lubricate if necessary.
Mar 14, 2010 | Riso RZ310 Duplicator
Riso gr 3770 error T14
how can i solve the Error T14 for Riso Gr 3770
Thanks
May 12, 2009 | Riso RZ220 Duplicator
I have error Code of T11 in My Riso GR 2750 As I live in Myanmar we have no card to use
thats a timing error u will have to line up the drive chain not an easy procedure u really have to know what ur doing
Apr 15, 2009 | Office Equipment & Supplies
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Riso gr 3770
- Please check if they have Master Roll Jam?
- Install properly the Master Roll.
Sep 18, 2008 | Office Equipment & Supplies
857 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
