Question about Sony RDR-VX500 DVD Recorder/VCR
Sony RDR-VX500 does not load some dvds, disc error.
5 days ago I started having issues where some dvds are giving me disc errors. the confusing part is that it is not all. ones that are failing continue to fail, time and time again. ones that succeed, do so every time. i have cleaned the ones that fail, but this does nothing. i have cleaned the dvd player. bear in mind all of my dvds work 5 days ago. i am completely confused. any ideas.
Are some of the discs 8x and other 16x, it won't do 16x.
Posted on Jan 07, 2008
Try the disks in another DVD player. If they play with no problems in another player, then you have a hardware issue with your Sony. Nowadays, if it is out of warranty, fixing it is not worth it, because it is cheaper to replace, at least in the USA.
Posted on Jan 15, 2007
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
Jun 13, 2012 | Panasonic Televison & Video
Tip
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
Boot Disc Failure
The disk boot failure could come from a number of sources. I can offer some solutions one or a combination of which will hopefully correct the error.
First, check your BIOS settings to see if S.M.A.R.T drive reporting is enabled. To enter into BIOS please tap F2 key at start up. In the BIOS screen, if the S.M.A.R.T drive is enabled, disable it and give it a test run of 2-3 days under a regular rebooting cycle to see if the error persists. S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology)is a somewhat outdated standard developed as an "early warning" system to detect hard disk issues. If your desktop is newer, it may not even be available as an option as it is not widely used these days. The SMART technology while useful under certain circumstances had an extremely wide margin of error and would throw errors on boot occasionally when there would be nothing from either a physical or configuration standpoint failing or pending failing in the drive.
While we're in the BIOS, I'd recommend that you ensure that it is recognizing the drive correctly on each startup. The easiest way to ensure this is to reset your BIOS default settings. While on the BIOS screen, look for an indication either along the top or bottom designated by one of the function keys (I believe it used to be F10 to restore defaults). Be sure to save your changes and exit. Again, where you did not get the error every time, you may need to monitor it's progress to see if the error returns.
Second, physically check all cabling. A loose or in some cases failing IDE cable (assuming it is an IDE and not SATA connection) will produce these errors in the Pavilion line (and most others I would well imagine). Power everything completely down, remove the side of the case to give access to the drives and start with reseating the cable both at the drive end and the controller (where they plug into the motherboard) ends. Ultimately, if you were to pick up (or could somehow borrow) a different IDE cable to test for a short time it may also call out a failed or failing cable as well.
Third, we can't overlook the possibility of a failed drive itself. Formatting and/or recovering the drive will most likely not correct an error of this type. If any of the steps resemble those suggested above and have already been attempted, the issue may well point to the disk itself. How old is your system out of curiosity. I realize this option is quite a stretch given the timeframe.
Keeping with issues with the drive itself however, if all steps listed above don't correct the errors, there could be a strong possibility of a failing disk. Since you say it will boot on occasion the failure may not be severe enough at this stage to completely fail, but a total inability to boot may be looming on the horizon.
I hope one or a combination of the recommendations I've made correct your issue. Keep me posted if possible.
Thanks and Regards,
Mithun
Jul 13, 2010 | Computers & Internet
My player keeps giving me a bad disc error no matter what DVD
Realign the laser. I'd take it to a shop & let a technician do it
Mar 12, 2010 | Cyberhome CH-DVD 300 DVD Player
Dell Inspiron 531 gets me crazy..
hello, sounds like memory issue, I would say if you have more than one stick of memory in it remove one at a time and try it again.
also while you are at it reset BIOS by remove battery from motherboard and/or switching jumper setting.
hope it helps.
regards
Amar Sondhi
Dec 05, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
No disc error only for DVDs
This is problem laser unite replace it
Sep 05, 2009 | Sony DVP-NS575P DVD Player
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
When trying to play DVDs the words unknown disc title appears. Even after several attempts with various DVDs we havent had any success.
have u tried cleaning the hea of ur dvd player?after using a dvd player or cd player for long times of continous play say 6 months or if u play too many scratched discs and u dont clean the head of the player it starts skipping the disc or many a times dosnt recognise the disc so it'll give u errors like "Unknown Disc", "Disk Error" etc so i would really recommend u to clean its head using a dvd head cleaner cd.. its easily available in the video stores or malls.. u can purchase any dvd head cleaner cuz there are number of manufatcures for this. im sure this would solve ur issue.
PLEASE DO RATE ME,WOULD REALLY APPRECIATE IT
THANX
Oct 06, 2008 | Philips Televison & Video
When a disc is loaded, it reads "no disc".
Okay, so I had this problem a few days ago and started watching movies on my X-box 360. Then my X-Box came up with the same error as my DVD player. After reading countless reviews and e-mailing Samsung, I read somewhere that someone had pummeled their X-Box until it adjusted the laser back.
So, I pummeled my DVD and X-Box into oblivion and oddly enough both of them are working. Don't go crazy smacking it but give it some sturdy hits right above the CD tray as you are putting CD's in and opening the tray. Worked for me and hope it helps...
Aug 17, 2008 | Samsung DVD-HD850 DVD Player
Cant write DVDs with my DVD+RW RW8165 Drive
your drive may not be compatible with -rw disks. Try using +rw. They are totally different.
also i am having a similar issue with vista with burning dvds. I have to set it on 4x or it fails around 90 % up to 99%. Lower your max burn speed.
Aug 13, 2008 | Computers & Internet
Sony RDR-VX500 DVD Recorder/VCR Logo
271 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
