Start up error overclocking problem
Everytime i turn on my computer an error occur about overclocking,then the computer tells me to press F1 to fix it on the bios ,after fixing it when i try to restart my computer same error occcur ,the day ,date, and time of my computer goes back to january 1, 2002 ,12:00hours can you please help me what to do?
    Genius:
  • 1,913 Answers
When u poerr up the computer press DEL or F2
then u enter in bios set date and save .
Posted on Nov 12, 2008
My win xp has a coprocessor error can you kindly tell how to fix it my problem includes a bus controller error
Hi
Assuming you have not tried to overclock your processor, it would seem as if this is a BIOS or Motherboard Chipset Driver conflict or corruption.
Try first to clear the BIOS.
To enter BIOS (check bottom of POST screen for the correct key to enter SETUP), when in SETUP, select correct key for Reset to Default Values, then press F10, then press enter.
If resetting BIOS does not fix the problem, reinstall the Motherboard Chipset Drivers and then restart the computer.
If you did try to overclock the computer, then enter the BIOS and reset BIOS to default values, then save changes and restart computer.
Hope this helps.
Aug 22, 2011 | Computers & Internet
I have an IBM Think Pad type 2373. whenever I turn the computer on I get an error: 0210: Stuck Key 01 It says to press F1 to fix it, I do this and nothing happens. Can you please help me fix this?
F1 may appear as a secondary key on your computer. When the error message starts, try first pushing the 'Fn' key (near Ctrl), and then clicking the F1 button. Then you can follow your computer's instructions to fix the problem.
May 02, 2011 | Computers & Internet
Try to put operating system in computer comes up with overclocking failed error how do i reset or fix overclocking problem
hit F1 or DEL right at boot repeatedly until it enters bios. look for cpu/frequency, perhaps underneath "chipset" or "advanced" settings. lower the cpu/frequency a little, until it boots, or look for "auto" settings for the cpu/frequency and ram speeds.
Nov 23, 2010 | EliteGroup 945P-A (945PA11) Motherboard
I have some problem on my PC which is running window XP pro. When I switch on my pc. It will prompt me the message below: ''Overclocking failed. Please enter setup to re-configure your system. Press F1...
The BIOS settings are wrong. Press F1 when the pc starts to enter in the BIOS then on there you will see the Load default settings option: select it, Save and Exit. If the problem isn't fixed then you have some jumpers on the motherboard that are switched wrongly - take them all out and try again.
Nov 12, 2010 | Computers & Internet
It says cpu voltage error pls press F1 and i did it but instantly swiches off why? pls help me
and do you still have anny errors? when did this occur, after overclocking?
please some more info :)
Jan 12, 2010 | ASUS P5LD2-VM Motherboard
Computer fix
i had same problem last week i ended up having to use a recovery disk to format my hd ... i also had the boot sector write message it came up after a while of pressing f1
Oct 26, 2009 | Computers & Internet
One morning I turned on my PC, and it gave me Overclocking failed error. Press F1 for something I dnt remember.. access bios or w/e. so now I went to Bios , pressed f9 for the default settings then I...
If you had been overclocking you may have fried the CPU chip.
You MIGHT try cooling the thing better and for sure blow out any dust occluding the fans.
There is a chance you have a virus that deliberately clobbers the BIOS settings.
Oct 13, 2009 | Intel Motherboard
I have an ei system 103a desktop i have had to sytem restore now when i turn pc on it tells me to press f1 to start windows i have tried going into the bios and boot from hardisk but still have the problem...
The 'Press F1 to continue" message is a result of an error caused as the BIOS does its hardware checks during the boot process.
The BIOS boot process (bootstrap) preceeds the loading of the operating system.
The most amusing example of this occurs if you unplug a ps2 keyboard,
1, it generates the error
2, pressing F1 does no good because the keyboard is not plugged in.
3, if its ps2, you will need to do a hardware reset after plugging the keyboard in again.
The bios can be set to 'halt on'
'no errors' which will stop the error message appearing.
'keyboard errors' see above
'all errors' any hardware failure detected by the bios will halt the boot process and give the above message.
Mar 11, 2009 | Computers & Internet
Hi melnavz,
Hello!
Make sure that the battery hold firmly in the mother board and should no be drain out or busted to hold the time setting in the cmos. this is the only things that you need to observe. if the system keeps on asking the setting then battery is the main problems that cannot hold the time setting in the cmos.
tell me if problem still occur.
Mar 13, 2008 | ASUS P5RD1-VM Motherboard
A disk read error occured
Your system BIOS no longer recognizes your processor. I'm going to assume you haven't replaced the processor recently, in which case it is a bios error. Can you enter the bios on startup, or does this occur before that? On most computers there will be a message saying something along the lines of "press F1 to enter setup" - of course, it could be F1, F2, F10, F11, F12, DEL or ESC... or possibly another key Try hitting all of those and see if it takes you to a BIOS menu. If you can't get to the BIOS, you're going to have to replace the motherboard. If you can get into the bios, you may be able to detect your processor from there. Without knowing specifically what bios you are using, or what motherboard so I could find the bios information, I can't say more. If you can get into the BIOS, it should tell you what version it is (usually on the top somewhere). Get me that information and we can go from there. If you can't get into the BIOS, it's time to replace your motherboard. Or, honestly, for a system of that age it might be cheaper to just buy a new (or used) computer to replace it.
Aug 28, 2007 | Intel Pentium III, 800MHz (229725001)
Computers & Internet Logo
418 people viewed this question
David Payne
David Payne
