Question about HP Computers & Internet
My computer crashed and will not boot back up. It says File\minint\system32\ntkrn1mp.exe could not be loaded. Error code 32768. my computer is an HP that I purchased from costco and it did not come with windows xp discs. they were already loaded when I purchased it.
  • 345 Answers
Most HP computers if you press F11 right after the bios screen , it should go into the system recovery partition
Posted on Nov 13, 2008
    Scholar:
  • 69 Answers
Hi wiredstone,
Unfortunately it is very likely that you will need to reinstall windows. I understand that you don't have the windows disks but there are other disks called restore disks that should have come with the pc. WARNING when you do this then everything on your hard drive will be gone and it will be as clean as the day you bought it.
If you don't have any of these disks you will need to buy windows or take it to a pro for reformatting (they get reformatting licenses)
If you don't have backups of your information and need the data on your hard drive you can backup the hard drive by removing it and connecting it to another pc Or getting a pro to do it.
that said its possible that some of your hardware has failed.
As to why this happened could be due to many many factors like software conflicts, overheating, viruses.. etc.
I'm sorry to give you bad news but it happens.
  • 57 Answers
Hp should have an option on your boot menu (viewed by pressing f8) to boot to system partition. Try that and see what kind of options are there.
How to fix \minint\system32\kdcom file cannot load error 4 Emachine
Download this file to your computer and burn it to a CD:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
If you don't have an app that can easily burn .iso files to a CD then get this awesome little FREE app and install it:
http://www.majorgeeks.com/downloadget.php?id=4870&file=9&evp=0636b68877cb69b15faa3374cb1dcd89
The Bootable CD you burn should fix your computer. It's really easy to use. Just follow the instructions from page 15 to page 33 in this pdf:
http://support.kaspersky.com/downloads/guides/kasp10.0_rescuedisk_en.pdf
You basically want to update the virus definitions and select all of the checkable boxes to scan and run the scan and then allow it to delete or quarantine the bad files.
Sep 01, 2012 | E-Machines eMachines Desktop PC
C:\minint\system32\restore.log mising
Restore points are located in C:/Windows/system32/restore.
You have an unusual error message which talks about C:/minint folder. Seems like this is a virus issue. It would be better if you run virus scan for your computer.
Also run a system utility software RegInOut to refresh your PC.
Dec 13, 2011 | Computers & Internet
Acer 5520 notebook startup issues
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Dec 23, 2008 | Acer Aspire 5100 Notebook
Error: windows root>\system32\ntoskrnl.exe
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
Desktop Error Message
Probably this is a spyware, use a good anti spyware or do the following:
Run Process Explorer (right click on task bar>task manager>Processes) and Kill the Following Processes:
wscript.exe
dxdlg.exe (kill this one first)
Run Autoruns and under logon tab, remove
C:\WINDOWS\system32\wscript.exe C:\WINDOWS\system32\boot.vbs
Search for entries named wproxp and remove it
Remove the following files from your PC:
C:\WINDOWS\system32\dxdlg.exe
wproxp.exe (Most probably in your system32 or windows folder)
Jul 06, 2008 | Computers & Internet
PC Recovery
Hi I found this I hope it helps
You may try to rebuild the boot config from the recovery console, if you have the Windows boot disk or recovery console installed.
bootcfg /rebuild
http://support.microsoft.com/kb/314058
Regards,
Spud
Jun 18, 2008 | HP Compaq Presario C304NR Notebook
My Acer Aspire 5004WLMi Crashed and will not boot with Acer recovery disks
turn on your computer when it stars to boot up simultaniously press F8 button run for safe mode then try to launch system restore.
Jan 21, 2008 | Acer Aspire 5004WLMi Notebook
Computers & Internet Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
