Question about Sony KP-51HW40 51" Rear Projection Television
Light blinks 8 times
When tv is turned on, screen turns green and then shuts itself off. Light on front of tv blinks 8 times.
  • seahawks80 Feb 19, 2008
    yep i get a flsh of green the a shutdown and tuner/stand by light blinks 8 times. i made the turn as advised. pic came back and left again after about 15 minutes of being on. looking for some direction.. can someone help a brother out here.
  • Killer MXZ Apr 15, 2008
    I have the same problem, but mine is red on a KP-57HW40- blinks in the standby and shuts down- what up?!?!?!
I did a last minute search to do the repair myself before I called somebody. I found this and figured "This will never work!"
I followed his suggestion and now my TV looks better than it has in months!!! I'M SO RELIEVED!!!! Although I really want to upgrade to a flat screen LCD or PLASMA but I'm not ready for the expensive. I have had this SONY for about 6 years!!
THANKS TVDUDE!!!
Posted on Feb 08, 2008
Best Solution by Guest worked!!! Great job and Thank you!
Posted on May 02, 2007
Thanks it worked for my blue problem. J
Posted on Apr 20, 2008
My daughter kicked her shoe into my TV today and the green screen thing happened. Thanks to that Best Solution... my TV looks better than before. It was very easy and took only a few minutes. Thank you so much for posting that.
Posted on Apr 08, 2008
Well i thought i'll be upgrading my TV for a new LCD or plasma TV, but after doing this solution......dang, i was able to fix it. Thanks for this easy quick fix.
Posted on Mar 08, 2008
I'm 58 years old. Have had red lines forever. Tonight turned tv on and it faded to blue.Kept on shutting off Red led light flashed 8 times Read your info. Decided I had nothing to lose. I actually fixed it myself. Probably just a quick short time fix but I'm happy tonight. I guess I'll start looking for new TV. Don't know if I'll go with another Sony. I've this one for 5 years. Should last longer than that (I think)
Posted on Jan 29, 2008
Its unbelievably easy to fix. there are 2 screws holding the front speaker cover on (there are plugs covering the screws that you take out first).Unscrew and reove speaker cover(you got to give it a bit of a tug to get it off ) then remove the piece of wood cover held by 4 screws .. Once you have taken that off when you look down you will see 6 screw like adjusters with a white painted mark on them (do not touch top row ) the green is controlled by the bottom middle screw ,, witha screwdriver turn it counter clockwise (to the left) ever so slightly (1-3mm)and there you have your TV back .. when the screen turns red use the bottom right screw and blue bottom left screw.. I hope this helps
Posted on Dec 29, 2006
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
I replaced the lamp however the green light blinks for a minute then the lamp light comes back on and the tv can't be turned on. WD-Y57 model
with that model after the tv shuts off pres the "menu" and "device" button on the front panel buttons together for about 8 seconds and then the power led will blink green. it will blink a certain number of times then pause and blink a different number of times this will be the error code for the fail that the tv thinks it is having. for example it may blink green 6 times then pause and blink 1 more time that would be code 61 check the code and repost and i will tell you the next course of action good luck
Jan 05, 2011 | Mitsubishi WD-Y57 57" Projection HDTV
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
379 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
