Question about Prima CV2011 TV
Tv locked have a good picture on the one chanel that works but no other chanels and no volume control i have the same problem but with tv prima model Q2770
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi was there any spillage earlier? if theres it can stuck one of your button. press each button carefully & listen if it sounds like others,because if one is stuck ,others will not function untill its release.do this why your tv is unplug if stuck ,change the button or the entire pad. if not, press & hold the menu button & plug the tv to the mains & power on .thanks
Posted on Nov 12, 2008
  • olayoju victor Nov 12, 2008
    if all this fails try & refer service to qualify service personel. consult a fix ya tech around you
    Brigadier General:
  • 6,966 Answers
Offhand, a couple of possibilities you may want to explore/check:
  • pls check if any of the front panel control buttons/keys are stuck by flicking at them with your fingernail;
  • replace the batteries of the remote.
Should neither be corrective, try to reset the unit back to factory defaults by unplugging the unit for a considerable period of time, say an hour or so. If problem persist, you may have to consider either a DIY (do-it-yourself) internal diagnosis/repairs or seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Sergeant:
    Champion:
  • 347 Answers
Hello den005796,
have you tried to contact your cable provider? It seem to me as a problem from the cable provider and not your TV
  • Prima Master
  • 19,396 Answers
Try first unplugging powr cord for ten minutes, to see if this can unlock channels.
  • Ginko
    Ginko Nov 12, 2008
    The TV has a parental lock on:
    press the remote's DISPLAY button multiple times that should unlock the tv, let me know.
  • Ginko
    Ginko Nov 12, 2008
    If the first method did not work, try following the instructions here Removing parental lock on RCA and GE TV...
    Sergeant:
    Novelist:
  • 196 Answers
Check out the cable connection.that may be faulty.
    Genius:
  • 1,847 Answers
Try do a channel scan and then try.
  • Legin Varghese
    Legin Varghese Nov 12, 2008
    Are you having the same issue with the other TV? make sure the signal is proper.
    go to the menu and try resting to the factory defaults.
    let me know if you need more assistance...thanks..kevin
Chanel button changes input
Try 124 code, might work for combo unit.
Aug 19, 2012 | Innovage Jumbo Remote Control
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
No sound on tv chanel
hi, no sound with tv but have picture, also have lost sky but works on other tv with a tv link, tv make LG Lh3000
Apr 22, 2009 | Logitech Harmony One Advanced Universal...
Unable to tune in and get picture/chanels
try to reset ur tv to factory setting.....should be in ur instruction booklet...when done try to set to automatic channel search and it should find Chanel for ur area
Mar 14, 2009 | Televison & Video
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Setup correct but operations not so well (urc-3445)
Universal remote controls may not have codes for all functions of a device.
May 25, 2017 | One For All URC-3445 Remote Control
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Prima Television help me
theres a blak box with a code on my t.v
Nov 15, 2007 | Prima CV1311 TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Prima CV2011 TV Logo
Top Prima Televison & Video Experts
romy sibug
romy sibug
Jerry Greenberg
Jerry Greenberg
Are you a Prima Televison and Video Expert? Answer questions, earn points and help others
