Question about Ovens
Enamel chipping Hi, I did the mistake of leaving for a few minutes a cookware on the base of the oven (where the element is). Now the base enamel looks a little chipping/cracked but not much damaged though. The oven still looks to work correctly. I was just wondering if this could be toxic or not good to continue cooking in this oven? Thanks for your response!
    President:
  • 2,651 Answers
The interior of the oven cavity is chipping??? if so not a worry or concern for saftey or health concerns stictly cosemetic
Posted on Nov 13, 2008
Is the interior of the Neff B1691 oven made from vitreous enamel? The manual only describes it as 'enamel.' I'd like to use Oven Pride cleaner on it but it says to only leave the product on for two hours...
I have searched diligently and cannot find what the interior of the oven is made of. I suggest you open the owner's manual and find contact information for the manufacture. Call or email them for an answer.
Feb 09, 2011 | Neff B1691 Single circotherm super...
My oven has the blue enamel inside and I want to clean it. I read that the self cleaning mode can chip the blue enamel. Also I know that I should not use oven cleaner. What is the best method for...
Sorry to read about your problem, I hope this helps you out.
use regular oven cleaner, if you wish
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | KitchenAid KEBC208 Electric Double Oven
How can I re-enamel an old wood burning stove?
For my outdoor burner i use Krylon high temp flat black which works great for me, Sherwin-Williams has a large variety of high temp paint for your application.
Oct 10, 2009 | Ovens
I just noticed that the oven enamel is chipped in a few places where the racks sit. Do I need to replace the oven?
At this moment in time, there is no need to replace oven, it is quite o/k to carry on using it.
Please rate my solution.
Thanks.
Sep 19, 2009 | Ovens
I need to repair the enamel in the base of my oven. It has been removed in somne areas.
they make special appliance enamel touch up paint, which is good for a knick and a chip here and there. If its a bigger job than that, you may want to use a higher heat enamel. Ive used high heat engine enamel purchased at an auto parts store, which they formulate to work with the heat of car engines. It comes in a spray can, so it depends on the scope of the project/repair.
Aug 31, 2009 | Philips Ovens
Melted aluminum foil on oven floor
I'm not up on my science, but..it's like welding, or more like soldering, chances are it's a high temp metallic enamel paint, and the two fused creating a mechanical bond. Your stove is cooked. You may be able to scuff the bottom and repaint it with a new coat of high temp enamel.
Just remove the racks, undo the clips that retain the heating element,(so you can lift it some, DO NOT try to remove it) tape off the bottom to create nice clean edges, using a piece of 80 grit sandpaper scuff the paint really good, lay down a coat of primer if the directions call for it, and follow the directions on the can. Don't worry about the clips, close the door and turn the stove on to the temperature specified on the can, and leave it on for the time stated. It will bake to a smooth glossy finish.
Most of the products I've used go up to 1000 degrees, and bake at 400 for 4 hours.
Good Luck!!
Thanks
Aug 23, 2009 | Kenmore Ovens
Easy off ate all enamel off interior of oven
First off i must say that in your owners manuel it clearly states to not use any cleaning products inside the oven..
Second if the cleaner is now completely cleaned off then when put into the bake cycle it could possibly turn the cleaner into a toxic gas. I would not use the oven i would replace it.
Third having the enamel chip off is not a safety concern. it is merely cosmetic. however refer back to number 2.
Feb 13, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
How best to clean neff U1320 oven
The door itself is vitrous enamel, although I have not found it a problem if some gets on to it.
What you must ensure is that you do not put any on the element liners or covers on the sides. of the oven, otherwise it stains them.
Don't get it on any paint work either.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Ovens
Eurolec oven fire - gases released made us sick
Good morning Folk!!
A toxicity doctor rang me to say that I have been exposed to vitreous enamel and galvanised metal.
The composition has zinc, chromium, silica so when the gas came off the oven interior, I had "gas fever, short term toxic, that would be eliminated from my body with no expected problems. Apparently welders have this all the time. It causes irritability, nausia and sleepiness. Australia has very poor metal detection in blood testing. It usually has to be sent to America.
I don't trust Eurolec, nor the company who made their baked enamel ovens - Technogas Italy, who now produce for Euro appliances.
I'm getting a new stove - ILEVE - which is a better quality gas stove all round.
Bye for now
Sandra Petersen
Sep 17, 2008 | Ovens
Oven enamel chipping
The only solution I know of for the enamel coming off on these units is replacement of the unit, and since it is 4 years old you are going to have a tough time getting dacor to replace it or even give you a credit towards a new one. I have never actually seen the problem on a Dacor. Does the unit have a hidden lower bake element? If you cannot seee the elemnt its hidden, and you cannot put tin foil on the floor of any unit wiht a hidden bake element, as it will damage the finish. I know this isnt much help, but I work on Dacor products regularly as we are an authorized servicer, and I can't say I've ever seen a finish problem on one. Best bet at this point is to call Dacor and see if they will do anything about it. Good Luck!
Jan 12, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
275 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
