Question about Microsoft Windows XP Professional for PC
How do I restore Acer4520 to original specs and erase memory?
I purchased a used computer and cannot get it to restore
  • Microsoft Master
  • 4,338 Answers
If the hard drive has not been formatted,you can do an eRecovery from the recovery partition. Instructions are on this link:
http://www.acerpanam.com/synapse/data/7117/documents/Acer%20eRecovery%20Management%20v2.5%20-%20final.pdf
If the hard drive has been changed or reformatted,borrow cd from a Friend and re-install XP, using the license that should be on the bottom of the laptop. Then you can download the drivers from Acer's website.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 13, 2008
How can i reset my hp pavilion laptop?
The easiest way to clean the laptop up is to reinstall windows and reformat the hard drive. Was there a set of recovery disks/CDs with this laptop? If so you can do a system recovery and get it to factory specs. If no disks are available you may be able to create them yourself. information on this procedure should be on the HP web site where you may be able to purchase a set of disks/CDs.
Good luck, I will check back to see how your doing.
Nov 14, 2012 | HP Pavilion dv6000t Notebook
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
Dec 08, 2011 | HTC HD Windows Phone 7
I just purchased a used hp laptop at a pawn shop. it has no recovery discs. how do i restore it to the original settings?
use the system restore option or download a program called system rescue and run that or format HD. The system rescue program will erase everything and require re-installation of windows. System restore will bring back to original settings.
Oct 14, 2009 | HP Pavilion dv6000z Notebook
Pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
formatting the memory card automatically erases all the files in the memory card.
it's like restoring the memory card to factory settings to be compatible with your camera.
when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
May 31, 2009 | Samsung L100 Digital Camera
Need to restore pc to original settings, upgrade memory with 2gb memory card and restore my skype, email, etc
You can do a system restore by clicking start>all programs>accesories>system tools>system restore You can restore your computer to an earlier date just follow the instructions and restore it to the closest date to the date of purchase. You can also go on-line and order system restore disks from the manufacturer. The memory on a laptop is under a cover on the bottom of the laptop. Use a screwdriver to remove a cover and you can find the memory there. You should look up the make and model of the laptop to find out how much and what type of memory the motherboard / laptop will hold. Memory is easy to replace just pop out the existing chip and install the new on making sure you static discharge yourself before sticking your hands in it. You can usually do this by touching a metal case for a desktop that is plugged in or anything that is plugged in to a wall outlet and is grounded. When your finished, go to my computer. Right click and go to properties to see if your memory is being recognized by the PC. Then just re-install the apps. I hope this helps.
May 19, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Erased photos
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Apr 04, 2009 | Concord Camera Eye-Q 3340z Digital Camera
I can't restore my Apple IPod to original state for use.
Once you plug it in, does iTunes recognize it, if it does, then click your iPod in the left pane of the iTunes window, and choose restore, this will erase all on the iPod and restore it to the factory (out of the box) defaults.
Mar 29, 2009 | Apple Computers & Internet
Memory full reading
hi,
just try to find the factory setting and restore it on original. it will erase the memory and you can used it again..
rey
Nov 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Erased images
I had success with this
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery software (simply because i was using it and it worked)
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
Jun 29, 2008 | Polaroid T730 Digital Camera
System Restore
All your files are now marked as not in use. What this means is they could be "undeleted" if some went about doing so. Over time they will get overwritten has the pc is used more and more. If you are worried about someone recovering your data then you need to do a wipe of your hard drive using a program like DBAN. Then you'd need a recovery cd handy to restore the pc, since after doing the wipe the hard drive will be completely erased... Hope that helps.
Jun 12, 2008 | HP Compaq Presario SR2150NX PC Desktop
Microsoft Windows XP Professional for PC Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
