Question about Microsoft Windows 98 for PC
Step by step on how formatting and fdisk and installation?
Step by step on how to make a fdisk and formatting and installation?
  • 83 Answers
Okay, heres what ya need to do.
Procedure:
1. Get Windows install disk(s).
2. Turn on computer with cd in drive, press F12 or F2 untill you get to the options that allow you to boot from the CD.
3. Delete all partitions after CD loads, then create new partitions.
4. Then continue on the installation and click next untill its done.
5. to make fdisk, put in a floppy drive after the installation, Go to My Computer, then right click on the floppy drive and choose create fdisk.
Hope this is clear enough, if its not just ask.
Posted on Nov 12, 2008
I cont install xp3
first save your data. Then boot from a bootable floppy or CD that has 2 additional files on it. FDISK and Format.
Run FDISK first and follow the prompts.
Then run Format.
Then use your XP3 installation disk.
It should work.
Jun 06, 2012 | Compaq CQ60-215DX Notebook
Yesterday I buy a Samsung Laptop model R538 but with Linux Julia preinstaled. I want to change the OS with Win XP. I begin the instalation and at the point in which I know he want to format the disk I get...
Solution:
1. Boot into Linux.
2. Use "fdisk" command to delete "ext" partitions. // In fact, no need to use other tools (e.g. killdisk)
3. Run "fdisk" command as root.
4. For those who don't know how to use "fdisk", I provide an example here. (Read the man page of "fdisk" will be better)
//Remember !!! fdisk can format your hard disk (which will erase all your data), use it with great care -- unless you know what you are doing, otherwise don't use it. (I will not take any responsibility of my suggestion)
i) fdisk /dev/sda
.) For those who use PATA (Parallel IDE) : fdisk /dev/hda
.) For those who use second hard disk : fdisk /dev/sdb (2nd SATA hard disk), fdisk /dev/hdb (2nd PATA hard disk), fdisk /dev/sdc (3rd SATA hard disk) and so on ... {sd [a, b, c, d, ...]}
.) fdisk "what" depends on where your linux partition is.
ii) use "m" to read the available options
iii) press "d"
iv) press the number of the partition you want to delete
v) Remember ! if you don't want to make the change, press "q" at any time. (that means quit without saving)
vi) If you want to make the change, press "w" (that means write the change to hard disk)
5. There may sometimes cause a warning message say something about not synchronize the disk (because you cannot make changes while you are using the partition -- if you are booting the partition now), the change will occur after you shutdown and reboot the system.
6. Okay, you can reboot the system now and you will find that the partition is empty now.
7. You can install XP or what ever now.
** For those who cannot use "fdisk", my simplest suggestion is to re-install Linux if you don't have any other tools (such as killdisk). And then you should be able to use "fdisk". In fedora 8, you can even choose formatting the hard disk in "vfat" file system (which can be recognized by almost all computer include windows xp and so on -- see "File Allocation Table" wiki) during installation. Therefore, no need to run fdisk
May 31, 2017 | Hitachi Travelstar 5K500.B HTS545050B9A300...
I need to reinstall windows 7 and I was told to fdisk the hard drive on my laptop to do a clean install. If I need to do this can you tell me how to fdisk a laptop hared drive
Before you get into all of this ... try to restore your computer to an earlier date ... if that doesnt work, most manufacturers have the original software for the computer on a special section of the hard disk, called a 'restore' ... try those before you get into the fDisk business. Otherwise you will soon be way over your head ... This process is for someone who has experience in the process. Belive me when I tell you fDisk is not your first and best alternative.
Nov 01, 2010 | Computers & Internet
Cant install windows
System will show CD as C: and "COPYING" doesn't make drive "BOOTABLE".
You have to let the restore CD do the whole process of FDISK, FORMAT and INSTALL.
If you want HD bootable with no "WINDOWS"
use this command at A: prompt.
FORMAT C: /S
I'd have to get out my Win/DOS notes for more.
Try "Help Format" if that doesn't work.
I would Let the CD do everything if you are not familiar with DOS installs.
Apr 08, 2010 | IBM ThinkPad A22e 2655 Notebook
Presario cq60 104tu
The master boot record maybe be corrupted or virus infected.
To fix the MBR, boot up with your DOS disk and type fdisk /mbr
Then install XP, and delete all partitions and then create a new partition, then do a full NTFS format on the new partition.
Feb 27, 2009 | Compaq Computers & Internet
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
C drive formating
The basic fdisk command to repair the mbr is fdisk /mbr. that will replace the mbr but you may have to re-partion reformat and install from scratch. Good Luck
Dec 09, 2008 | Computers & Internet
Unable to format hard disk.
ady,
You did not mention what steps you have tried. and what the problem occurs when you try to format. It also depends which OS you are using.
There is a solution very easy to use. If you have Win98 or older version then try to boot with command prompt only aund then run FDISK. Using FDISK delete all partition and create new partions, then try to format and install your OS.
For Boot Disk you can surf/download from BootDisk (click here)
If you want detail help, please post your problem in details.
Thanks
Iqbal
Aug 07, 2008 | HP Compaq nx6310 Notebook
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
122 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
