Question about LG DLE2512W Electric Dryer
My LG Dryer timer gets stuck on 6 minutes everytime
MY LG dryer gets stuck on 6 minutes and we have to turn it off manualy
  • 2 more comments
  • brad_bailey Nov 17, 2008
    exact same problem, counts down to 6 minutes and will keep running while the timer sits at 6 minutes
  • Anonymous Nov 24, 2008
    We have had this problem on and off for over a year.....
    We were told the dryer sheets coat the sensors and make them non-functional.
    I am still looking for a solution.
  • dmprice2000 Dec 17, 2008
    I have had this problem 4 times now since mid 2006. I've heard all of these solutions and none worked. The main boards have been replaced 3 times as well as another timer board. It just failed again this week. LG has again GIVEN me an extended warranty long enough to cover the parts replacement now for the 2nd time. This is a bigger problem and LG knows it. Call them and have all of your Sales documentation ready. THIS IS A FIRE HAZARD.
  • TammyBoBammy Mar 25, 2009
    Just noticed by fluke tonight that my dryer was stuck on 6 minutes otherwise it could have been a VERY different night. We were having a quick dinner and then heading out for a few hours. I asked my husband before he sat down to dinner if he could run downstairs and change wash loads. He said the dryer still had 6 minutes. I thought it seemed weird but didn't think too much of it. Just before we were to leave the house, I ran down to switch loads and low and behold '6 minutes' left. The clothes were very dry and HOT. Here's the kicker we are 3 days past the 2 year parts and labor warranty! 3 Days...what a frickin' joke.
Look inside the drum on the right side of the filter. You will see two metal strips, thee are humidity sensors. Wipe them down with soap and water. It worked for me. The info came from LG tech support.
Posted on Dec 02, 2008
I called LG with the same problem and they said never to use dryer sheets. I wiped everything down and stopped using dryer sheets and have not had a problem since.
Posted on Feb 04, 2009
Timer stops at 6 minutes but continues to tumble.
You will need to replace the auto dry sensor on your dryer.
Mar 11, 2012 | LG DLE2516 Electric Dryer
My dryer won't shut off. The timer gets stuck at 6 minutes remaining. It will go for hours if I don't monitor it.
It appears that you need to replace the timer. Also try unplugging it for about 15 minutes, if it is an electronic glitch, sometimes powering it down, and then back on corrects this issue, but it is more often a problem with the timer.
Jan 03, 2011 | LG DLE2514 Electric Dryer
Dryer wont start, makes a humming noise. I have to manualy turn the drum then the dryer will start
Check the belt to see if it is worn or loose. If it has a capacitor start motor, the capacitor or motor could be going bad also. If the motor is spinning but the belt is not turning then you have a loose belt.
Jun 14, 2010 | LG DLE2532W Electric Dryer
Stuck on 6 min and wont finish the cyrcle.
if its not on sensa dry the timer is bad
Apr 22, 2010 | LG DLE2512W Electric Dryer
LG dryer won't shut off - gets stuck at 6 minutes
Your problem seems to be the timer switch is faulty.
Timer switches are normally non-repairable. You would need to replace the faulty switch
Oct 04, 2009 | LG DLE2532W Electric Dryer
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
Dryer on sensor dry - gets stuck on 6 minutes and does not finish
We have been having this same problem. I had tried adjusting everything that I could think of when putting a load of laundry in and got the exact same results as you. I would select the sensor dry and it would count down just like normal until it got to 6 minutes and then it would just run forever at 6 minutes.
My husband and I searched online all this afternoon and came across what seemed way to simple to work. We removed the lint filter, unscrewed the filter housing right inside the door of the dryer, and got to the sensors. We took a damp cloth and wiped them off very well to remove any and all buildup. We wiped everything down very well to remove any built up lint and/or dirt and put everything back in place as was before. We then unplugged the dryer for about a minute and then plugged back in. We put a load of already dry clothes into the dryer and started as usual with the sensor dry. It started out at the usual 41 minutes then skipped down almost immediately to 6 minutes and then a few minutes later I heard the most beautiful sound I have heard in a long time. The Beeper signalling that the timer had counted down to the end and was finished. It had worked. Thankfully. Hope this helps you also.
Feb 10, 2009 | LG DLE2512W Electric Dryer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
We had this problem three times. First two times we just removed, cleaned and put back the moisture sensor (metal strips inside). The last time we did as well but it didn't help. We phoned to a service guy and he said unplug the power cord for 20-30 minutes. And it worked!
Nov 12, 2008 | LG DLG2524 Gas Dryer
LG DLE2512W Electric Dryer Logo
2,457 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
