Question about Nikon COOLPIX P3 Digital Camera
Nikon Coolpix p3 will not turn on
Have several batteries and all are fully charged but camera will not turn on - any suggestions?
Thanks
Mike
    Champion:
  • 225 Answers
If they are the same batteries you always have used, then it is probably a bad system board. Replace the system board.
Posted on Nov 13, 2008
NIkon cool pix 5400 will not turn on. Battery is fully charged.
A couple of possibilities. The battery is bad and not accepting a charge. Replace the battery. The battery terminals are dirty. Using cotton swab and some isopropyl alcohol, clean then fully dry the metal contacts on the battery and inside the battery compartment. Before turning it back on, be sure everything is fully dry.
Jun 26, 2016 | Nikon Coolpix 5400 Digital Camera
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn on¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Jan 08, 2016 | Nikon Coolpix S6700 20.1 Megapixel Compact...
My nikon s4100 coolpix does not turn on
Hello Ice,
Please check the battery of the Nikon Coolpix 4100 Digital Camera. Please check the battery is fully charged or may be its damaged if its swollen. Also check the contact points of battery and camera and clean it. Insert the battery and charge it fully. When the battery gets charged fully then press the power button 4 to 5 times to start it. If the battery is damaged then replace the battery with new battery.
Jul 04, 2011 | Nikon Coolpix 4100 Digital Camera
Nikon coolPix 2200 will not turn on.
Hi
Try doing basic troubleshooting, turn camera offf, remove the battery. Reinstall battery after a minute or two and try turning it on. Make sure battery is fully charged.
Hope this helps
Sep 16, 2010 | Nikon Coolpix 2200 Digital Camera
My lightly used nikon coolpix s570 has developed a power issue. Meaning that with a fully charged battery, the camera won't turn on. sometimes removing and reinserting the battery will get it to turn on....
If you have a second battery, fully charge it and try it. If you do not have a second battery, it make either be a defective battery or a battery that is not properly charging. Try powering on the camera until you get it powered up, either by reinserting the battery or turning it one. Then purposely use the flash and focus until you totally exhaust the battery. Then charge it for the recommended time. Try the battery in the camera once more. Also look into the battery compartment and make sure there is no corrosion. After these actions, the only other thing I could suggest is trying a new battery or sending it in for repair. Usually it is the battery though.
Mar 22, 2010 | Nikon COOLPIX S570 Digital Camera
Display will not turn on. Battery is fully
Hello
Thank you for using FixYa for your problem
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Nikon Coolpix 8700 Digital Camera
My coolpix s50 won't turn on. to my knowledge it hasn't come into contact with any water or liquids and the battery is fully charged. is this something i can fix myself or do i need to send it to nikon?
Happened to me before. Suggest you try and check the battery cover lid, close it properly because there is a sensor underneath there, where it will turn off the camera if the lid is open. Try it several time and ways. Hope this might help, it does to me and now my S50 is working perfectly... cheers!!
Sep 29, 2009 | Nikon Coolpix S50 Digital Camera
Nikon D40x indicate battary low
Rechargeable Lithium-ion 7.4V 1000mAh Nikon D40x battery for sale,20% off! Full one year warranty! For more info visit: http://www.nikon-coolpix-replacement-battery.com/d40x.htm
May 13, 2009 | Nikon D40x Digital Camera
Nikon COOLPIX P3 Digital Camera Logo
242 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
