Question about Samsung Yepp YP-Z5QB MP3 Player
My mp3 player won't sync from my computer
When I try to synchronize a song from my computer my cpu says "cannot be synchronized due to I/O error". what does this mean? Is there any way to fix it? Thank you for the help.
SOURCE: "playback error"
Try replacing the songs, like, putting them on again. I don't know 100% if it will work but mine had the same problem and this worked.
Posted on Nov 14, 2006
  • 790 Answers
SOURCE: loading library error
format the player once and load again ...
Posted on Nov 28, 2007
  • 70 Answers
SOURCE: Samsung syncronizing
try using rhapsody instead of media player. See if that helps. Alternatively you can use winamp - it does the same things.
Posted on Dec 22, 2007
SOURCE: i can't download songs to my player
i cant download vedeo songs to my samsung yp-T9j vedeo player
Posted on Dec 27, 2007
  • 1554 Answers
SOURCE: computer wont read mp3 player when connected
is the USB device enable in the computers bios
does any usb device detected by the computer.
go to the control panel/system/device manager
does it show usb devices
Posted on Feb 26, 2008
SOURCE: i cant delete songs
you need to go into my computer find the mp3 and go into where the music files are you should be able to delete them from there
Posted on Aug 03, 2008
0 characters
1 Points
Hello...i have a Kingston 512 MB data traveler USB flash drive that i can't figure out how to delete all the songs and start new and put the songs i want on it! i am using my windows media player and when...
Synchronizing is the computer syncing the songs to the player, you have to leave it on till it finishes syncing.
To get rid of your songs the easy way follow these instructions.
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 07, 2011 | MP3 & Digital Media Players
Help cant put music to my mp3 player!!!
sounds like its defective i just loaded my music straight from WMP return it and get a new one.
Dec 27, 2009 | GPX MW3837 MP3 Player
I can't listen to my SpiralFrog music!!!
That's the problem with DRM licensing. Do yourself a favor - only download mp3 format songs to the player, and you will never have this problem. If you want to use SpiralFrog, delete all songs that are on your mp3 player now, make sure your spiral frog sub allows transfer rights, and reload the songs.
Aug 30, 2008 | SanDisk Sansa e250 MP3 Player
Synchronize to continue your music subscription
please use the windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Have a nice day!
Jun 13, 2008 | SanDisk Sansa c200 MP3 Player
Why is it like this?!!!!!!!!!
You have automatic synchronization set up, and you will want to disable it (set up manual synchronization) in order to prevent this problem from occurring in the future.
Connect your Go Gear to the computer
Open Windows Media Player
Highlight the Sync Tab
Click on the little black arrow and pull down the drop down menu
Click on Set Up Sync
Uncheck the box that says "Automatically synchronzie the device..."
-Tha Mp3 Doctor
Mar 31, 2008 | Philips GOGEAR SA6045 MP3 Player
What does "synchronize to continue music subscription" mean
the best way to put music into the mp3 player is by using windows media player 10, click on sync and put all the songs you want in the sync list then click on start sync and it should sync properly without any problems.
Jan 23, 2008 | SanDisk Sansa c200 MP3 Player
Well...when ever I sync songs to my Sansa. I never change the mode and it syncs FINE! You should try it
Jan 11, 2008 | SanDisk Sansa e250 MP3 Player
Error Message
You have to synchronize your Sansa to a computer that has a current subscription to Rhapsody, and you have to sync the Sansa to that same computer at least once every 30 days, or the Rhapsody songs will stop working. Use a different music service that is free, or convert all of the songs to Mp3 format to get around the problem. If you get a subscription to another music svc, then you must maintain a current subscription with whatever new svc you choose as well.
Dec 27, 2007 | SanDisk Sansa e260 MP3 Player
Synchronize to continue... message
you need to hook the mp3 player back up to your computer and go up to the sync tab if you have media windows player 10 then but your songs on the right panel then when your done go back up to the sync tab and click on the very first thing on the top of the list this should help you with the problem.
Dec 25, 2007 | SanDisk Sansa e250 MP3 Player
Songs not synchronizing
Are the songs in either .MP3 or .WMA format? If not, you will have to convert them before syncing.
Otherwise, are you getting any error messages when you sync? What do they say?
Are you using Windows Media Player to sync?
Nov 07, 2007 | Philips HDD1630 MP3 Player
Samsung Yepp YP-Z5QB MP3 Player Logo
16 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
