Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
No spark At sparkplug Gas blower mod.#Ry08544
I replaced the sparkplug, but still no spark
    Scholar:
  • 149 Answers
Remove the wires that go to the stop switch and see if there is spark..If none replace module..
Posted on Jan 15, 2009
  • 163 Answers
First check to make sure the on/off switch isnt shorting out anywhere. try resetting the gap between the flywheel and the igniton module. you can use an index card or manilla envelope to set the gap. if it still doesnt work try replacing the module
Posted on Nov 29, 2008
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
I have no spark on my ryobi 990r. i have replaced sparkplug. i have checked and have plenty of fuel
make sure the gap on the plug isnot to wide other wise u will not get any spark or just a weak spark
May 11, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I HAVE A POULAN BVM200VS BLOWER...WON'T START I HAVE PULLED THE FLYWHEEL AND KEY IS INTACK...I HAVE A SPARK AT THE PLUG..REMOVED CARB AND CLEANED....REPLACED GAS WITH FRESH GAS..SET GAP ON IGNITION MODULE...
If you have a spark, it's not your ignition or flywheel because they both work together to make the spark.
Give a starter fluid squirt into the sparkplug hole (instead of thru the carb), screw in the sparkplug and give it a try.
Check your muffler to see if it's stopped up. You can just remove it for the initial check when trying to start w/starter fluid.
Oct 07, 2017 | Poulan Garden
I have a 25cc Craftsman Blower/Vac model 358.794941 which will not start. I have replaced the spark plug and carburetor. This is 2 years old and not even 10 hours on it.
hi
if you have compression and spark(a blue one) try priming the engine,put some gas in the sparkplug hole and start the engine.if it fires only the gas you putted inside there is a delivery problem to find and fix(carburator and hoses.
bye
Oct 05, 2009 | Craftsman Garden
Poulan leaf blower/vac won't run. It has spark, head bolts are tight, spark plug wet with fuel. (New plug) Any suggeastions?
that's the problem gas when wet won't burn
remove the sparkplug and, dry it off with rubbing alcohol then reinstall prime and, restart
Aug 31, 2009 | Garden
Please let me know what I haven't checked
Do a compression test.If fuel mixture was too lean possible you scored cylinder wall or washed the rings out. Let me know, hope thats not the problem. (Last thought check primer bulb).
May 13, 2009 | Garden
Crafsman gas blower: fuel lines to primer bulb had to be reconnected; now blower won't fire at all. Replaced plug and made sure it sparked; still nothing when I try to start.
Hi
Priming the engine(put some gas in the sparkplug hole ,after you have checked the sparkplug,the colour of the spark has to be violet).Start the engine.If it starts there is a carburation problem,change the fuel lines to primer bulb.
wish you good luck savumihai71
Dec 04, 2008 | Craftsman 4 Cycle Blower/Vac
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,112 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
