Question about Whirlpool GGQ8831L Gas Dryer
Cannot open the bottem panel to clean out lint
I have a Kenmore dryer (about 11 years old) and want to open the bottom panel to clean out the lint. I cannot find how to open it. Please advise
  • 640 Answers
Ok please always unplug will fine two clips between the top panel and the bottom panel almost to each corner,,take a small putty knife and push in...onthejob
Posted on Jan 06, 2009
How do you take off toe panel from he3 electric kenmore dryer to clean plugged lint
My name is Peter. I am a retired field service appliance technician.
There are two spring clips, one on each side of the bottom toe plate panel.
Dec 02, 2014 | Kenmore Dryers
I want to clean the inside of my DLG0452W. Hasn't been done in 10-11 years. This is all part of venting. It properly. Can I take the bottom panel off?
i looked up your model and it looks like you haave to remove the top panel and then the front panel to get to the inside cabinet,if on the front you do have an access panel on the bottom then yes you want to remove the bottom front panel,pull out the lint filter,remove the duct that the lint filter slides into and clean that,then with a shop vac vac out the cabinet,then set the shop vac up to blow and blow all the lint from the back forwards and blow off the motor,this way you don't have to pull the belt and drum.when that's done go to the back and remove the vent line from the dryer,if it's a long run to the outside,go outside and make sure the duct is open,no cage or screen blocking it,go back inside,stick a leaf blower into the vent line and blow it this once a year and your dryer will run better and last longer but mostly you won't have a fire.hope this helps.
Oct 08, 2013 | LG DLG0452W Gas Dryer
My dryer will not dry effectively, it is very slow to dry even on the high heat settings, any ideas?
i looked up your model number and you have a gas dryer not electric,if the vent line is clear and the metal duct that the lint filter slides into is clean i would say you have bad gas coils located on top of the gas valve,when the coils go bad they will work correctly for the first 15 to 30 minutes,when they heat up they fail and the flame won't ignite,so do this remove the screws that hold the bottom panel on,remove the panel and vac out any lint you see,if you have a shop vac you can set the vac up to blow and blow off the motor and blow all the lint forwards and vac it up,do this with the dryer unplugged,remove the lint filter and take out the screws that hold the metal duct in place and clean the duct out,put it back together except for the screws that hold the bottom panel in place but just stick the panel in place,put some clothes in and start the dryer,after around 20 or 30 minutes remove the bottom panel so you can see the ignitor,if the ignitor glows orange but the flame doesn't ignite and the ignitor goes out then you have bad gas should take the bottom panel off and remove the lint filter duct and blow and vac it out once a year,also if you vent line is long remove it from the back of the dryer and blow it out with a leaf blower,make sure nothing is blocking the outside vent like a cage or a piece of screen so the lint can blow out and not get blocked.the part number for the coils is 279834 and they are around 25 dollars,unplug the dryer,remove the bottom panel,remove the two phillips head screws,remove the cover,slide the coil up and off of the post,unplug the wire and connect it to the new coil,watch out on the big coil,there's a spacer that has to stay on the post,sometimes it gets stuck in the old coil when you remove it,let me know how you make out.
Mar 19, 2013 | Kenmore Elite HE4 Electric Dryer
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Dryer won't get hot and dry clothes
This site will show you all the parts of your dryer ente your model num. To get to your thermostats you have to open the dryer up. You may have 2 screws at the very bottom of the front panel. If not then pry the top up with wide screw driver and from there it can be figure out.
Mar 20, 2009 | Kenmore Dryers
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Electric Dryer 68731
If still heating, clean out vent and check for kinks. Also, REMOVE PLUG FIRST!! Remove back and remove four screw holding filter duct assembly at bottom left. Pull duct toward rear and reach into bottom of duct and remove lint. Also, wash out filter screen.
Nov 17, 2007 | Kenmore 659 Electric Dryer
Whirlpool GGQ8831L Gas Dryer Logo
79 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
