Question about GE 21028GE3 Cordless Phone
Voice Mail messages too short, cuts off callers
Is there a way to make the answering system accept longer messages? All people get is 5 seconds-10 seconds, most people don't even get a chance to leave their number, let alone a message. I don't see anywhere in the manual in the section under "answering system" that addresses that issue, but it's a pretty useless message system without the ability to leave longer messages. It couldn't be a memory issue, as this happens even when there are no saved messages.
SOURCE: Memory Full?
I unplugged my power supply cord from back of phone and replug it again, I found there were in fact four messages. After I deleted them I was able to use the memo button again. So perhaps this willhelp you, too. Ackey320
Posted on Sep 02, 2007
SOURCE: "new voice mail" display
call your phone service and have them disconnect the voice mail and if they cant just remove that have them set there rings at like 9 since most phones only have up to 5 rings for the machine to answer.you will have to use there voice mail service to hear your message and then delete it but should be good after that. i have comcast and they said it would take 3 days to deactivate voice mail but told me how to get there so i can get rid of that flashing light, hope this helps you
Posted on Nov 28, 2007
SOURCE: GE 29893GE1-B Digital Answerer Problem
G.E.speaker phone model#29322GE1-a how to program other numbers in phone
Posted on May 17, 2008
SOURCE: Reset the answering machine without the manual
GE 28112EE2 1.9 GHz Twin Cordless Phone
Flashing CL.
Lost Manual.
Can you help.
Posted on Jun 23, 2008
SOURCE: visual message waiting indicator
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Posted on Dec 20, 2008
Panasonic voice mail works fine except when our line is busy callers get the busy signal and are unable to leave a voice message
Yes - Afraid that is the case, certainly in the uk.
Phone will only accept a message if phone is not in use / not answered.
You do get notified that there is a call waiting so you can either switch to their call and ask them to call back.
Or when you have finished call - their number will show as last caller and you can call them back.
Nov 02, 2016 | Panasonic Lands Phones
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Our voice messages from outside cut off before message is complete. How do we fix this?
How long are they speaking before it cuts them off?
is it 180 seconds? That is the default for IP office, but you did not state which system this phone is plugged into...
Feb 28, 2013 | Avaya 1408 Digital Phone 700469851
I have the panasonic phone but when someone called me after 3 rings it goes on answering machine. i wanted to make it longer at least after 5 ring. please help me with any suggestion.
You can set your ring time to 5, 10, 15, 20, 25 or 30 seconds.
  • Tap **61*121*11* into your phone as if you're making a call.
  • Next enter a time between 5 and 30 (the number of seconds in multiples of 5)
  • Press # and then the call button. Don't put the phone to your ear - just look at the display until you see a message confirming your ring time has been set.
For example, **61*121*11*25# followed by the call button would set your ring time to 25 seconds.
Jun 11, 2011 | Computers & Internet
How do we set up the phone system so that an outside caller can call our extension directly without having to go through reception/main unit?
There are a couple of ways. The easiest one is to use the Panasonic voice mail system which has an auto attendant built-in. It can be programmed to answer incoming calls, play a menu and let the caller dial extensions or ring the operator. If no one answers, it can take messages and provide the voice mail for the system. The TVA system has a LAN card that can send voice mail to email. It's optional in the TVA-50 and included in the 200.
Carl
Mar 14, 2011 | Panasonic KX-T7630 Corded Phone
Panasonic kx-t7453 corded digital super hybrid system How do I turn my voicemail box on so a caller can leave a message at my extension? thank you
Pretty much, it depends on what happens when you dial 165. That's the voice mail access number for a Panasonic TD phone system with Pana VM. If you get the voice mail lady, set the box up and then from the intercom dial 7102/3/4/5 where 2 is all/3 is busy, 4 is no answer and 5 is busy/no answer and 165 or whatever the VM access number is and possibly # (I forget if it's required). That will light the FWD/DND light and send calls to the voice mail system.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
Unable to leave voice mail, says good-bye
I don't think the voice mail is going bad.
On my 4424D+, I can turn off voice mail.
I use this feature when I'm gone for an extended period of time so I don't come back to 100 VMs.
Dial into your voice mail.
Choose the prompt for Call Answer Mode. (Option 8 on my phone.)
Then choose the prompt for Record Mode. (Option 1 for me.) This allows callers to record voice mails on your line.
Feb 17, 2010 | Avaya 4412D Corded Phone
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
Voice Mail drops last of message and cannot listen entirely
It's possible the system thinks the caller has completed the message because they make a long pause in what they are saying. OR does it ever cut them off in mid sentence? Do you use standard copper lines or are you on a VOIP network such as a cable provided phone line? Some VOIP lines produce slightly different voltage levels, ring signals etc.. and cause problems with sensitive equipment like this system. On these codes that Panasonic had you change. Were they A/B on/off etc.. or was there a range (like 1-10) and you can try a setting in the middle somewhere instead of just 1 or 10. The older system had a phone line setting of A or B. The default was A but often changing them to B made a difference on certain types of phone lines. Panasonic probably had you change this (if the same feature is available on the 4500) but if not, and it's there try that.
Oct 06, 2007 | Panasonic KX-TG4500B Phone
GE 21028GE3 Cordless Phone Logo
79 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
