Try to set it with an other code said to your device brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
firstly the satellite dish antenna must be correctly aligned to satellite you want to receive. technosat setup" initial setup" select the correct safelite ,once selected u should see signal strength /quality then tune the channels...auto works best, after this you can create your own favorite channel list
I AM HAVING TECHNOSAT RECIEVER IT IS SHOWING BOOT & SYSTEM LOADING ON THE PANEL I WANTED TO CONNECT IT TO MY PC THROUGH USB - SR232 CABLE BUT IT IS ASKING FOR HARDWARE DRIVER CD - MY RECIEVER MODEL IS TS 5500 SS II
PLS.SOLVE MY PROBLEM I NEED DRIVER FOR MY RECIEVER
