Question about Technics SL-1210 Turntable
I have 2 Technics SL1210MK2's that are in serious need of refurbishing. Can you recommend a place that does this work?
  • 515 Answers
Posted on Dec 13, 2008
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
Numark ttx shortage
Shortage?, no the vestax pdx 2000mk2 has shortage, the numark is not a well build unit from the. inside. I just can buy the ttx in store. Which is inside mostly oem%#}#%. Buy a te hnics , refurbish it yourself and tkake the kabusa straight/s-shape option, then atleast you have a proper tonearm and unit, but scewing arm together is very bad for your stiffness and the s-shape is very bad . Just but a s shape board and straight arm. You miss the accuracy and stiffness, which aint great on a te hnics also and the connection is a sad built for the money. I purchased half a year ago a vestax pdx 3000 mix and that unit is way better built then the the 2000 pro with the j arm
and it\'s new from the inside.
My mk-5 is also new, costing me 1000 euro and then i have a pgd. micro electronics. The average technics mk 2 is worn out stuf and a waste of money and the refurbished ones, ain\'t real refurbished. Buy a pioneer, then atleast it\'s new, with oem parts inside offcourse. Or you have to live in the netherlands and i can tell you what to need to need to renew on a technics, which are all caps, a lot a resistors , the two var resistors, tonearmcables and removing that stupid standard rca system and put nice rca\'s on a plate on it and the feet for new feet or just isokinets, since used technics have no usefull rubber anymore in the feet.
May 12, 2014 | Numark Audio Players & Recorders
Toshiba cannot find operating systom
It sounds like a drive failure, if you hear clicking noises then you have a very serious internal problem (heads or platters), I would recommend removing it and seeing ig you can access the drive on another machine, failing that you might need to send it to a recovery compnay such as Digital Recovery (www.digitalrecovery.co.nz) or you local one.
Dec 25, 2013 | Toshiba HDD2H02 250GB 5400RPM 8MB BUFFER...
Trying to track down a tonearm plug in connector and stylus for an SL-BD22. Is it possible to get the connector separately? Can you recommend the best place to get them?
Hi, Is it the headshell you want like this?
If so I have 1 in stock $39.90 USD. I also have an original Technics EPC 24 P mount cartridge with stylus which were fitted to SLBD series $49,90 USD. Cheers John. styluscity@gmail.com
Nov 10, 2011 | Technics SL-BD22 Turntable
Technics SL-1700 Mk2, tonearm doesn't lower, cueing doesn't work
There's a rubber belt or O ring that broke. I couldn't find one at Technics, so I took the old parts to the hardware store and found an O ring in plumbing parts that was very close. Been working for years just fine!
Eddie
Jul 16, 2009 | Technics Audio Players & Recorders
No Power to turntable
Why not try replacing the whole power chord with new one instead of just changing the fuse ( but you will have to splice the two wire lines at the end of your turntable console if not to resolder it, and be sure to properly mask it with an electrical tape to avoid electrical hazard/shock to anyone... ;-)
May 24, 2009 | Technics SL-1210 Turntable
CD's come out distorted on the TECHNICS SL PG 580A
TRY NEW RCA JACKS AND TRY BLOWING IT OUT,,GET YOU A LASER LENS CLEANER
Feb 26, 2009 | Technics SL-PG480A CD Player
D600 latitude motherboard
I recommend Ebay. You can get a good used motherboard for around $100, just make sure that the motherboard is guaranteed to work, so your protected if it doesn't. I've gotten many used boards off Ebay, and had no problems. Used or refurbished is just fine, there's really no sense in paying the $400 for a new one. If the $150 refurbished has at least one year warranty or better, that would be the route to go. Here's a link to Ebay's listing for the D600 motherboards. If you need assistance in changing out the board let me know.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37.l1313&satitle=dell+d600+motherboard&category0=
Aug 27, 2008 | Dell Latitude D600 Notebook
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
Mar 25, 2008 | Technics SL-1200MK2 Turntable
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
101 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
