Question about Magellan eXplorist 400 GPS Receiver
Problem turning on unit with SD card
I just purchased this unit and when I put in the SD card that came with it and push the power button, the screen turns black and nothing else happens. When I take the SD card out and push the power button, the unit turns on and works fine. Is the SD card bad or is the unit bad. What should I do. Thanks
    Novelist:
    Scholar:
  • 86 Answers
Make sure all the contacts that the SD card touches are even in the back. Sometimes the contacts will be bent out of shape and end up grounding themselves. So, get you a pair of tweezers.. and look closely. dont' be afraid to bend them back.. they shouldn't break off. Good Luck. -Daniel
Posted on Feb 03, 2007
Forgot password
  • Turn off the unit.
  • Take a microSD card out of the slot. (Empty the microSD card slot.)
  • Press and hold down the power button for a few seconds while pressing and holding down the "Home" (Silver Push Button) button. (Both "Power" and "Home" buttons must be pressed down until he see the phrase "upgrade system activated" in the middle of the screen.
  • Release both buttons once the phrase "upgrade system activated" appears on the screen.
  • Wait until it reboots. You will see the following sentences on the left top corner of the screen: Can not find any update image. Press MENU/KEY_VOLUMEUP key to init SD card, Press BACK/KEY_VOLUMEDOWN key to cancel.
  • Press the "VOLUME UP" key. The volume up key is located at the left side of the unit and the button is closer to the built-in camera than the volume down button.
  • Wait until it finishes making a partition and shut down the system automatically.
  • Once the unit is turned off, your system will be reset to the factory settings. Thus, your previous data are lost at this point.
Nov 15, 2013 | Coby Kyros 716829701508 Tablet PC
How Do I Get Past a Pattern Lock MID8024
  • Plug the unit into an electrical outlet.
Aug 23, 2012 | Coby Kyros MID80244G Tablet
720 Go is frozen. Press the reset button and nothing still get the same screen with a harddrive in the corner. Put it in the cradle and the computer doesnt see the unit when it is on?? Have tried to let...
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for at least 20 seconds. The reset button is a hole at the base/bottom of the device.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds or more, until the GPS starts up. It may take a minute or two of holding it down.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Sep 02, 2011 | Tomtom GO 700 GPS Receiver
I have a Kenwood DNX7120 and the physical buttons on the bottom (att, vol controls, fnc, nav, src, etc) suddenly stopped working. Now, I have the remote control, so this isn't TOO much of a problem,...
My unit has the same issue, started a few weeks ago.
Here is a forum post where someone was able to fix their DXN7120 by replacing the button panel: http://www.kenwoodforums.com/viewtopic.php?f=11&t=1247
Here is a parts diagram showing the buttons (PN: X16-628):
http://www.pacparts.com/reference/880/DNX7120.pdf
Maybe someone could write up how to get the panel apart? Otherwise I will once I get the replacement part.
Nov 27, 2010 | Kenwood DNX7120 Car GPS Receiver
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Can get to the tomtom screen with the green charger light on , but no further. freezes at this point and difficult to switch off. need help
Make sure that you leave the unit plugged in for two hours, and remove the sd card, if you have a card in it.
On the top or bottom of the unit is a usb port and a reset button, take a paper clip and open it, then put the paper clip into the little
reset hole and push in for 30 seconds.
Turn on unit, hold the on button for 5 seconds, now turn off, now hit the reset button again as said above and then power on and run though
your menu and see if this did the trick, if not you might have to send the unit in for repair.
Please post back if you need any more help.
Feb 06, 2010 | Tomtom One XL GPS Receiver
Basic screen when turned on...can't do anything else.
You will need to do a soft reset here are the instructions:
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
    Press the On/off button for at least 5 seconds.
Oct 16, 2009 | Tomtom GO 910 GPS Receiver
When i start the lucca 3.3 mp3 it shows "upgrade sd card" and it locks up. I tried to reset but i only get this popup screen. Someone knows a cure?? thnx...
I had same trouble with my Lucca 3.4 and I resolved it.
1/ From "Lucca 3.4 GPS DVD" I copied all files from /Recovery  onto SD card
2/  With SD card inserted I started Lucca3.4 pushing 2 buttons (together)
  Switch ON/OFF and MENU, and he will reimage rom (took about 8min)
3/ when GPS auto-reboot-ed I pushed YES on screen and he started to upload
soft,files (took about 20min)
4/ after this I reinstalled maps from Lucca3.4 GPS DVD
Now my Lucca 3.4 works fine again !
BR
Dan
Feb 22, 2009 | Blaupunkt TravelPilot Lucca MP3
Blank screen
To reset your TomTom device:
1. Charge your device.
Charge your device for at least 2 hours. Make sure the charging light on your device is on (except RIDER which has no charging light).
2. Remove the SD card.
Use a straightened paper clip, or something similar, to push the reset button. For a visual representation of the reset button, see below.
Press and hold the On/Off button for at least 4 full seconds.
5. Insert the SD card.
images of where to find the reset button can be found here.
Sep 04, 2007 | Tomtom ONE Regional Car GPS Receiver
DNX7100 - new unit, screen won't power up
It only goes down half way. You have to gently push it down the rest of the way to expose the SD card slot.
Aug 23, 2007 | Kenwood DNX7100 Car Video Player
Magellan eXplorist 400 GPS Receiver Logo
77 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
