On my Brother HL 2140 series printer, I changed the toner. I followed the directions that came with the toner, and it just won't work. When I put it in, the error light always comes on. I tried unlplugging the printer and taking the toner out a few times and putting it back in.
  • 2 more comments
  • Anonymous Nov 26, 2008
    same problem as above
  • Anonymous Dec 10, 2008
    Put new toner cartridge in BR HL-2140 but toner light is still yellow and I can't print
  • socalnate1 Jan 24, 2009
    Same thing! The toner error keeps me from printing anything. Extremely frustrating.
  • Anonymous Feb 26, 2009
    Toner light never goes out, won't let me print anything.
  • 3 Answers
Open the front cover
Turn off the printer
Keep the go button pressed and switch on the printer
Once all light is lit release the go button
Press the go button twice again
Press the go button six times again
Close the front cover.
This should solve the problem
Posted on Mar 05, 2009
  • 1 more comment
  • zarni123 Jan 20, 2011
    This method work very well every time I had issue with toner. Thank you Jimmy Virdi
  • Terry Ashmore
    Terry Ashmore May 12, 2011
    Don't know what it was that I was doing but it worked great
    Thanks mate
  • HunterCobra Aug 01, 2011
    JimmyVirdi, my hero, worked a charm, thanks man.
On the toner cartridge, just to the right of the refill hole ( you know... the one that has a label tape over it warning dire consequences... fines, prosecution, imprisonment, etc... if you remove it ) there is a small plastic window that allows the printer to see if there's toner in the cartridge. There's one on the other side too, so if you hold one up to a light you might see that light though the other. Sooo.... simple! Cover the window with a bit of black tape, and if you're lucky you can keep printing! Useful if you're right in the middle of a print job and want to finish!
Of course, if you are really running low on toner ( and this proves it... it's not a driver glitch... or maybe the printer's "toner-detect-light" is too bright ) you will likely run out soon. But I've had this problem when print quality was still just fine... and it gets me through a few more jobs.
Posted on Nov 23, 2009
I have a brother hl2140 and need to change the cartridge but the drum is stuck. Is there something I am missing?
Posted on Jun 12, 2010
Tip
Resetting Blinking Toner Light HL-2140
Here is the procedure for resetting the Toner flashing light on Brother HL-2140 (sources for other answers here and self testing - specific to HL-2140)
  • Open the front cover and leave open.
  • Turn the printer off.
  • Hold the "white button" while turning the printer on. (All panel lights should be on.)
  • Release the "white button".
  • Press the "white button" 2 times (Pause, wait for all lights to come on.)
  • Press the "white button" 5 times. (All lights to come on again, then go out.)
  • Cancel "maintenance driver" install, if prompted
  • Close cover.
  • Power cycle printer.
This will:
  • reset the toner light (stop blinking)
  • restore the printing darkness (when toner light flashes, printer prints lighter to save toner)
  • keeps the printed page counts and drum life info
on Mar 06, 2011 | Brother HL 2140 Laser Printer
How do I access and change out toner cartridge (brother-HL2140?
To get the exact detailed instructions for how to replace the brother HL-2140 toner cartridge.Please click the link below and follow the instructions:---- http://technoanswers.blogspot.com/2011/02/how-to-change-toner-cartridge-on.html ------------- Keep updated.Thanks.Helpmech.
Feb 25, 2011 | Brother Office Equipment & Supplies
How do I access and change out the toner cartridge? (brother HL-2140 printer)
1 Turn your Brother HL-2140 laser printer on.
2 Open the front cover by pulling the top latch toward you.
3 Pull the printer drum unit toward you. Put it on the clean, blank sheet of paper.
4 Push the green lever on the drum assembly down.
5 Remove the empty toner cartridge from the drum unit.
6 Shake your replacement toner cartridge gently to evenly distribute the toner inside.
7 Put the new toner into the drum unit and slide the unit back into your Brother HL-2140 printer. Close the top cover.
See also Brother user manual for this model at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Feb 25, 2011 | Office Equipment & Supplies
Printer not printing documents HL-2140 model
when the toner light is on this means the toner cartridge is empty and ned to be replaced. After its replaced it will start working normally again.
Jun 02, 2010 | Brother HL 2140 Laser Printer
HL-2140 Clean Corona wire Message won't go away.
If you are getting "clean corona wire" on your PC and the toner light on the machine is solid, you need to change your toner cartridge.
This is a bug in the brother software.
Thanks,
Pat
May 11, 2010 | Brother HL 2140 Laser Printer
HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
Oct 02, 2009 | Brother HL 1440 Laser Printer
HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Sep 30, 2009 | Brother HL 2140 Laser Printer
Black pages
Look inside the printer and make sure none of the pins that contact the drum are bent down.
Jul 02, 2009 | Brother HL 2140 Laser Printer
Toner
Trick the thing. Put a piece of black electrical tape on the "eye". (Take cartridge out, on right side there's a small clear hole). Worked for me!
Jun 30, 2008 | Brother HL 2140 Laser Printer
6,417 people viewed this question
jasbo
jasbo
