Question about Samsung PS42P2S 42 in. Plasma Television
Samsung PS-42V4S plasma TVwith black & white lines
I have a Samsung PS-42V4S with black & white lines.
Looking online many people seem to suggest dry solder.
As out of warranty had a look but discovered that the chips on the ribbon cables don't look soldered but instead in a kind of plastic depression.
any help appreciated
HDTV GURU
  • 261 Answers
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
It does sound a lot like a buffer board problem, Just which one is the question. Sometimes it is in fact a connection issue. But 1/2 of the screen missing sounds like maybe connection between the 2 buffer boards. It could possibly be the panel. If that is the case. ITs over for that set. But i would suggest first calling samsung and asking them to extend the warranty for 90 days or so. Sometimes they will do this for nice customer such as yourself. 1-800-SAMSUNG. Let me know how this turns out first then we can proceed further if needed. Good luck and keep me posted. Sincerely Jay
Posted on Jan 31, 2008
wwjdcgh
  • 114 Answers
SOURCE: Samsung Plasma Lines and Colors on Screen
first is it still under warranty through the manufacturer samsung is verry well with wanrranties
It sounds like it is most likely the plasma gas itself and in that case it would cost way more than what you could purchase another one for.
by the time you have a tech come out and fix the plasma gas tube itself yould be looking well over 1000
Posted on Mar 30, 2009
romsky79
  • 822 Answers
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
Posted on May 29, 2009
SOURCE: 50" Samsung Plasma with black screen
I had the same problem and had the TV serviced and found that the y board was blown $350 total. The repair guy explained that the board has a hot transister underneath that slowly leaked onto the board, but says that they can not get Samsung to admit to the problem. Works fine now but only have a 90 day warrenty on the parts.
Posted on Jul 01, 2009
  • 16 Answers
SOURCE: 2 horizontal blue lines on samsung 50 plasma tv
Possibly could be the Y buffers --if the are next to each other could be a bad connection on a ribbon cable ---you need to call for service
Posted on Feb 06, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Samsung Plasma ps-42s5h has two black lines running vertical with green strip in the middle
Ok we have to resolve the extent of the problem before diagnosing it. Does the black line/green bar show on all inputs and the tuner? Is it visible in the OSD (on screen display)? if yes to all of these questions, it could be a panel drive problem or a bad plasma panel. A picture would help diagnosis
Oct 19, 2008 | Televison & Video
I have a Samsung ps-42S5H TV The TV right to 3rd vertical bar shown black strip, What to do.? Please suggest me, I'm already removed the logic buffer board...
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 01, 2015 | Samsung Televison & Video
Mitsubshi 65 DLP with white and black vertical lines across the screen. Is it the DLP chip?
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 02, 2017 | Mitsubishi WD-65735 Television
Black Thin Horizintal Line " 6" from top of Panel
The ageing suggested is average.
If when changing the screen resolution the line doesn't move then a new panel is required.
Jun 12, 2017 | Televison & Video
Samsung plasma tv ps42c7hdx flickering lines
Yes, yes, yes. Change all bulgy, puffy capacitors by exactly the same value and voltage. Look for any excessive voltages in these areas where you find such capacitors. But replace capacitors only one by one. Never remove all of them together, as you are likely to misplace the capacitors, creating more problems. Also look for any loose contacts and dry solders.
Aug 04, 2012 | Samsung PS-42C7HD 42 in. HD-Ready Plasma...
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Ps-42s5h plasma goes black when warmed up.
we ( technicians ) call it a cold solder or burnt solder , just need to open the tv and give a VISUAL look thru the entire PC Board , good luck , AJ
Nov 05, 2009 | Samsung PS42P2S 42 in. Plasma Television
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Nov 16, 2007 | Pioneer PDP-425CMX 42 in. Plasma...
Samsung PS42P2S 42 in. Plasma Television Logo
64 people viewed this question
Henry  Thomas
Henry Thomas
