Question about Sony KP-61HS10 61" Rear Projection Television
Rear projection picture problem on Sony 61" big screen tv
Picture is blurry with constant flickery horizontal lines all over the screen. At fist it would come and go and could remedy the prob by banging on the tv or stomping on floor. Now it won't go away at all. Tried the auto "flash focus" button and it didn't help. I have aslo checked out playing a dvd and vhs and the picture is the same. Unplugged it and did what sony said to do, they said to get it serviced. Everything works fine on another tv set, so it has to be the Sony tv. What is wrong and how much will it cost to fix it??
    President:
  • 4,402 Answers
Sony had a problem with flickering, please confirm make and model number.
otherwise it sounds like a loose connection or bad convergance amp ic
Posted on Dec 20, 2007
Red lines, blurry picture
try this link. It fixed my sony.
www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 29, 2009 | Sony KP-51HW40 51" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Dec 31, 2008 | Televison & Video
Constant horizontal lines
Good Day, valscot;
The most common problem with model i some caps on the signal board, CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB.
good Luck big IRISH.
Aug 14, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Sony big screen tv, no color
focus block or neck boards on thr picture tubes
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Picture problem
Have you taken another set an hooked up the cable or sat. to the other tv from this tv? Try that first thing. Next try the video input like with a dvd or vcr. No lines ?? Then sounds like the tuner could be going bad in this set. if you still have lines then its a problem in the video or horizontal section in the tv set. There are no user serviceable parts inside this set so its anot advised to gointo this set to try to fix it. You can get a serious shock or cause more problems with the set. I know you said it is about 5 or so years old. Its at the point of do you wanna invest in this set?? If you really like the way it works then a tuner shouldnt (if thats the problem) run more then 2 to 3 hundred bucks with the labor. Good Luck
Jun 10, 2006 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
183 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
