Your computer is full of potential free ringtones for your Samsung T229 (also known as Samsung SGH-t229, T-mobile t229) :
By Bluetooth:The Samsung t229 is Bluetooth-enabled. Bluetooth is a wireless system which lets you connect your cell phone to computers, headsets, car kits, etc. If your computer is also Bluetooth-enabled, simply establish a connection between both devices and transfer your music files from your computer to your Samsung t229.
Simply record sound directly:Since your Samsung t229 has a sound recorder (also known as "voice memo"), a very simple technique involves simply placing your phone near your computer's speakers, playing whatever music or sound you would like as a ringtone, and recording it -- you can even use your voice, your child's voice or even your cat's "meow!" Record it with your mobile and there you go! Unless that function was specifically blocked on the Samsung t229, you should be able to navigate to the ringtones section and choose your new recording as a ringtone. Of course, the quality will not be ideal but, after all, it's free!
Downloading using the phone
NOTE: MegaTones, HiFi Ringers, and Voices & Sounds are stored at
Menu > Fun & Apps > Files > Sounds > Sounds.
To download using the phone, perform the following steps:
1.
At the main screen, select
t-zones.
2.
Scroll to and select
Music & Sounds.
3.
HiFi Ringers,
MegaTones, or
Voices & Sounds.
4.
Scroll to and select the desired category.
5.
Scroll to and select the desired tone.
6.
On the preview page, select
ACCEPT.
7.
After the tone downloads, select
Play to preview the tone.
8.
Select
Set as.
9.
Select one of the following options:
- myFaves ringtone: To set as a myFaves® ringtone. Scroll to and select the desired myFaves contact.
- Default ringtone: To set as the default ringtone.
- Caller ringtone: To set as a caller ringtone. Scroll to and select the desired contact.
- Alarm tone: To set as an alarm tone. Scroll to and select the desired alarm. Turn on the alarm and select the desired time and date.
10.
Select
Save.
same problem... is there a way to make the phone discoverable?
