Question about Canon Office Equipment & Supplies
Unable to connect my Canon Scanner D2400u to Adobe Premiere Elements 7. Have tried to download Driver d2400ufvs1611den.exe. Although driver seems to download adobe or my scanner does not seem to recognize it.
  • fwblais Nov 12, 2008
    I am trying to download a device driver for my d2400u canoscan scanner. The scanner on my new computer with OS Vista, keeps asking for the driver for my scanner. I can find it (d2400ufvs1611den.exe) and download it but my computer does not seem to accept it.
    Sergeant:
    Novelist:
  • 196 Answers
First check out whether your drivers which u r loading are compitable with vista operating system .
if it is not compitable it will not detect the scanner and will not work.
as the vista system is very much new this type of no detection problem r very much common.
thanks.
Posted on Nov 12, 2008
    Genius:
  • 1,913 Answers
  • kishor khatri
    kishor khatri Nov 13, 2008
    check your usb cable then try
    www.nodevice.com/driver/CanoScan_D2400U/get36923.html - 16k
  • Canon Master
  • 1,879 Answers
Does the Scanner work with other programs ? Try it from Start -> Accessories -> Paint
  • monk3ybidzness
    monk3ybidzness Nov 13, 2008
    You got the correct driver - After downloading it you got to locate and RUN the d2400ufvs1611den.exe file by double-clicking on it then the driver installation starts.
  • monk3ybidzness
    Don't forget to reboot the computer after the installation.
  • 4,472 Answers
What version operating system do you have? Is the scanner installed on your computer? you can find out by going to control panel in scanners and cameras folder. Once I have more information I can assist you further. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Nov 13, 2008
    Did you install the driver after you downloaded it? Have you ran the .exe file? downloading and installing are two different things. Once I have more information I can assist you further.
    Thanks,
    Lee
  • Canon Master
  • 19,396 Answers
On adobe you need to select scanner source .
  • Ginko
    Ginko Nov 12, 2008
    Using Adobe Premiere Elements you need to go to File menu, then select Import, and there you can select the scanner source.
    If the scanner is working on the computer, you should get the scanner listed under import command.
    First ensure the scanner is working outside Adobe Premiere Elements, then go to import command in Adobe Premiere and see if you can find you scanner listed, it should be in there.
Importing videos from sony hvr-hd1000e to premiere elements
hi,
you have to connect to your computer via FireWire cable, not USB !
Jul 16, 2013 | Adobe Premiere Elements 10
Canon scanner N650U using Vista unable to open "TWAIN server"
I have Windows Vista 32bit running with the driver from canon XP Driver - CanoScanCSUv571a.exe.
1. Download driver from Canon
2. Extract driver to CanoScanCSUv571a folder
3. Click Start orb and Control panel
4. Make sure classic view if checked
5. Double click Device Manager
6. Under imaging devices right click CanoScan N650U/N656U and select update driver software...
7. Select Browse my computer for driver software and click browse button to location of the CanoScanCSUv571a folder and click on Next button.
8. Ignore any warnings the driver works fine. Have been using it for a long time now
Sep 07, 2011 | Canon CanoScan N650U Flatbed Scanner
Using XP Pro, with correct driver. Error is "Unable to Select Twain Source. Edited Path to include: %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem; C:\WINDOWS\twain...
You will need to install the twain driver for the scanner.
Click on the link below and download the driver. Once its downloaded execute the .exe file. you will then get a small box pop up with "Unzip" on the right hand side. Look at the path of the unzipped file on the left hand side and save it to your desktop. For example C:\users\yourname\desktop instead of C:\Users\yourname\AppData\Local\Temp. The file extracts quite fast so go to the desktop and run the SETUPSG.EXE file. When its installed you should be able to use the scanner.
Download Canon Scan gear here >>>>>>>
http://modrv.com/scanners/canon/402prog.html
Good luck and kind regards.
Dec 14, 2010 | Canon CanoScan N670U Flatbed Scanner
Windows 7 cannot connect with scanner. Also only wants to burn a disk instead of installing from disk. More details. Scanner is plugged in and on. USB is connected to USB Hub, Hub is connected to computer....
look at downloaded driver is it exe extension . you need to run the driver program. If it is inf extension then you update the driver in device manager and select have disk.
Aug 06, 2017 | Visioneer OneTouch 5800 Flatbed Scanner
Install canoscan n650U with windows 7
sorry, none of the solutions listed above worked for Windows 7 on the N650U. will have to keep scanner on a stand alone computer with old Windows
Jan 19, 2010 | Canon CanoScan N650U Flatbed Scanner
Photoshop does not work on vista
When Adobe began shipping Photoshop® Elements 5.0 and Adobe Premiere® Elements 3.0 software in September, final versions of Microsoft® Windows® Vista were not available to complete the testing required to ensure compatibility.
Shortly after Windows Vista becomes available to consumers, Adobe plans to release updates for Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 to provide compatibility with Windows Vista.
Updates for existing Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 owners will be available as a free download from adobe.com, and updated Vista-compatible versions of Photoshop Elements 5.0 and Premiere Elements 3.0 will become available in the same timeframe.
tnx 4 using fixya!!!
Nov 02, 2008 | Computers & Internet
Adobe Premier Elemnts 3.0
This is most often caused by one of two things;
1. Out of Date Audio Driver
2. Old version of Quicktime
Update your audio driver and install the most current version of Quicktime, that should solve your problem.
May 31, 2008 | Adobe Photoshop Elements 3.0 plus Premiere...
37 people viewed this question
old marine
old marine
