Question about RCA 27V520T 27" TV
Shuts down Turns on,3 to 5 seconds a blue video veil comes across the screen from both sides and shuts down.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Posted on Sep 22, 2007
The play station turns on but the menu is not coming up. The wave line is on the screen of the TV
Same problem just happened to me. Playing a game and the game froze. Sat there in shock for about 10 to 15 seconds and the screen went black. Shut it off. Now every time I go to turn it back on again it starts up, I get the PS3 logo and then the blue wave starts. About 5 seconds after that the wave starts to lag and then nothing.... Stays on the lagging blue wave screen... THIS BLOWS!!!!!!!!!!!
Jun 15, 2010 | Sony Playstation 3 (PS3) Console
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
May 20, 2010 | Acer Aspire 6530-5143 Notebook PC
I have a kp65ws500 that turns on for about 5
These sets have a history of bad picture tubes-the tubes are only available on a rebuild basis and very expensive.
there is an option:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the green screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the green screen down until the set stays on and then very slowly turn it up until you see a slightly green screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
Regards, SD TECH
Mar 08, 2010 | Sony KP-57WS500 57" Rear Projection...
My sony kp-57ws500 turns on and works fine for about 15 min but then fades to blue then goes all blue. i took the back off and when it starts to fade to blue the green tube and red tube fade off. what...
These sets had problems with bad picture tubes that cause this exact problem, but there is something you can try that may help you get some more use out of the set.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is what you need to do.
7.) Once you locate the BLUE control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----turn it down slowly until the blue screen and trace lines just disappear.
If this works you may only be buying some time and if it is the tube sooner or later it may return with the same problem.
If this has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 19, 2009 | Televison & Video
Tv turns on then turns blue and turns off
This model had a lot of problems with bad picture tubes--the blue one is the most common to go bad--the tube will pull so much current the set will go into shutdown.
The tubes are only available on a rebuild basis--very expensive and usually not worth doing.
THERE IS ONE OTHER THING YOU CAN TRY TO DO TO MAKE THE SET WORK FOR A WHILE.
6.)Usually the blue will be on the bottom left--it does vary
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Blue Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the blue screen down a few times to get it to stay on.
IF this works you may only be buying yourself some time--if it is the blue tube causing this sooner or later it will repeat--I have seen several sets where the adjustment allowed the set to work for another year or more.
If this told you something you did not know, rate this solution as I do this here for FREE.
SD TECH
Nov 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Full Color fading to blue then screen turns off. Repairable?
8.) Best way to do this if the set is on is on a video input with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----if you get it to turn on this way turn the blue screen back down slowly until the blue screen and trace lines just disappear.
I do this here for free and if this helps you at all give me a vote here--it costs you nothing.
Regards, SD TECH
Sep 17, 2009 | Sony KP-65WS500 65" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
SONY KP-46WT520
does the led blink when it shuts down if so how many times does it blink? And the green line is that running up and down the screen or across the screen?
Apr 26, 2008 | Televison & Video
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
I need a replacement part # and location for the "BAD-Blue Signal Video Output Transistor"???
Actually, your description indicates that the blue gun in the tube itself is shorting out. This happens when the set has been on for a while and the metal parts in the CRT guns have heated up and actually contact each other. If the video output transistor is bad then your screen would be blue right from the start. An easy way to prove it is to monitor the voltage of the blue pin on the picture tube socket. It should measure around 150 - 175 volts. When the screen starts going blue you will see that voltage drop dramatically. Quickly pull the CRT board off the picture tube while watching the voltage on the blue pin. If the voltage jumps back up the instant the socket is removed, your picture tube is bad. There are CRT rejuvinators that have the "remove short" function, but that has about a 50% chance of success and I usually find that the short will return a few months down the road.
Aug 05, 2007 | Toshiba 32A33 32" TV
Televison & Video Logo
101 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
