Question about Kenmore Dryers
Replaced heating coil wont turn on
Lint started on fire coil burned up replaced coil and now it wont start
    President:
  • Kenmore Master
  • 2,651 Answers
You probably also blew out a few thermostats( high temp cut offs mounted on the heater can
Posted on Nov 13, 2008
The wash turns but there is not heat. Always remove lint and checked there was no blockage outside. Apparently there are two fuses and one may be gone. How do you get to the fuses to check?
Take off back cover after UNPLUGGING.
2 sensors in-line with heater element check for heat that is too high (so that you don't start a fire).
Check continuity on both, replace the one that fails at room temp.
If both check out, it may be a broken heater coil. Check Ohms on heater coil line(s). If infinite, line is broken and needs replacing.
Oct 03, 2017 | Dryers
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
My heat coils stay on when the dryer,only turn off if dial is on off position
A contact in your control switch has failed. Your fix is to order a new one at your local appliance
parts store (or online), and replace. In olden days, these switched were open, and burned contacts
could be "shined" with fine-grit sandpaper, but since appliance manufacturers discovered that old
arcing switch contacts could start fires (due to lint infiltration over time), the switches are now enclosed in sheet metal and must be replaced as a unit.
Apr 17, 2011 | Dryers
The dryer is just turning with out heat.it started with the long drying clothes long(over 4 hrs) then not heating anymore,cleaned and remove all lint built up, from exhaust to the front lint trap.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Jan 13, 2011 | Dryers
Roper elctric dryer model RES7648EQ make grinding and scraping noise when i start it. Found a bra hook cought in drum on inside of dryer took it out now when I started it it smelled like the belt was...
belts dont really burn the main reason for buring smell is lint on the element did you take the whole barrel out? as 90% of the lint that burns is formed around the heating coil behind the barrel
best of luck sir
Dec 02, 2010 | Roper RES7648E Dryer
1988 firebird formula 5.0 tpi car just died replaced feul pump,relay, fuse checked wiring changed module,coil pump wont turn on unless direct power car still wont start help please out of ideas
It sounds like you may have burned out your fusable link. It's a special wire that comes off the starter solennoid and is designed to burn off in the event of an overload. DO NOT REPLACE IT WITH REGULAR WIRE, THIS IS A LEADING CAUSE OF CAR FIRES.
You will want to check for what caused the overload condition that caused the fusable link to burn out in the first place.
Jun 21, 2010 | 1988 Pontiac Firebird
I have a 1988 chevy truck and it will not start now, i shorted out the starter and it burned the negative cable wire so i unhooked it and replaced the starter solenoid and replaced the egnition module,...
Is the engine turning over and just not starting? Go back to basics, you need fuel, fire, compression, and proper timing to get it to start. Check the fuel pump, do you hear it run when you turn the key on? Do you have fuel pressure, if so check for spark at the spark plugs, if you have spark try turning the engine over and have a buddy spray some starting fluid in the throttle body, if it tries to start then you have a fuel problem. If no fire check dist module, ign coil and coil wire.
Mar 08, 2010 | 1990 Chevrolet K2500
My Maytag PYG2300AWW is not heating. I have gas flow and the ignitor lights. But I noticed that when the temperature start to increase the flame goes out, and as soon as the temperature goes down, the...
It will shut down the heat if the vent or lint screen are plugged , are they free ? Also try washing off the lint screen with hot water, somtimes wax builds up on them from the sotener and wont allow air flow, you wont see it on the screen it is clear, but water will bead right up on it. easy checks before replacing a thermostat
Oct 29, 2009 | Maytag Dryers
Wont start after being turned off for at least 30 minutes
Im not sure what you mean when you say wont start after being turn off for 30min, do you mean the starter wont turn the motor over after 30min or the engine turn over but it wont fire/run? if it start every time after its cool down. check the coil, the original coil tend to fail with heat over time. if its original coil for being 1990 I would go ahead and place it. distributor Assembly unit will also need replacing if its original and having high miles. a sign of the coil going bad when it get hot it quit working until its cool off. fuel pump can be another causing the problem. hope that help some
Jul 21, 2009 | 1990 Honda Civic
I opened dryer and found burned lint. There was about a half inch of material around the heating elements that had also started to burn.
clean the lint out and make sure the coil is undamaged. dryers need to be taken apart and lint cleaned out once in a while. also clean the exhaust line out real good as too much lint can increase the back pressure, not letting all the lint out of the unit.
Apr 28, 2008 | Dryers
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
