Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsi tv hi ginko i think you are on the right track with that rear pro tv but it is had when the guy seems to have no tech knowhowany way cheers grant grantsreps
  • Mitsubishi Master
  • 19,396 Answers
Hi there, sure I am right.
Probably the user was confused from experts insisting on remote batteries and faulty remotes. They were just repeating user's incorrect diagnosis.
This things happen, sometimes you have to understand the user needs, or try giving valid advice in difficult conditions, like in this case.
Posted on Nov 12, 2008
TV will not turn on 2-1 and 2-2 error. ws65807
Mitsi has this information posted in regards to the 2 errors you have indicated. "2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies)" Also these 3 tech notes were found. "1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB.
2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB."
I hope this points you in the right direction.
Apr 19, 2010 | Mitsubishi WS-65807 65" Rear Projection...
Toshiba 2004
thats the protection ciruts causing the off and on,probably 1 of the modules.had simular problem with mine and it turned out to be the pcbaudio/video module a common problem with this mobel of TV costs about 168$ can for the module i hope this helps.From Moonbasealpha cheers mate....
Jun 14, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Flashing Green light!!
Having the same problem. Seem as if everyone who own this model is having or will have this problem. Hope Mitsubishi recall it for this problem.
May 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Double vision
The double vision is from bad convergance ic's and posibly some support resistors or pico fuses. if you are not an electronics tech I suggest to have one do it. the ICs can range from $45.00 to $60.00 each and is suggested to replace both of them. some mitsies had one IC which I cant remember how much it was. tech charges vary. some prices may be $150.00 to $300.00 shop around.
Dec 31, 2007 | JVC AV-48WP30 48" Rear Projection...
Hitachi Rear Projection
Hi! Guy,
I don't think your problem was caused by lightning. It sound like defective convergence ICs. This must be checked and verified by a qualified service tech.
Toprol
Oct 11, 2007 | Philips 60P8342 60" Rear Projection...
Rca p46771at won't come on post lighting.
Have you tryed to unplug for a while and plugging back in again.. Ff that dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Jul 25, 2006 | RCA P46924 46" Rear Projection Television
Have you tryed to unplug for a whiloe and plugging back in again.. if tha6t dosent work, something most likly in the power suppply blew out from a power surge.. if your not a tech or have TV experience it would be best to leave this to a pro. Too much Hi Voltage inside these sets to fool around with and do any experimenting! good luck
Toshiba
hi bad solder connections in the deflection and power suply ckts solder and then solder some more then look for leaky caps on the pc board and dicoloration ie turned black on the solder pads of those caps good luck
Mar 20, 2006 | Toshiba 65HX93 65 in. Rear Projection HDTV...
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
