Question about Toshiba Satellite A55 Tecra Notebook
S-video Problems Trying to watch a dvd on tv using my s-video port on laptop. Is there anything special I need to do on my computer to get it to work?
  • 93 Answers
After you plug S-video connector to your laptop, and hold Fn and press F5, you will see from screen, which ask you what video out put you want, you should choose TV, and you will can watch your DVD on TV screen, but you have to using audio output from your laptop too..if you want to use TV speakers or other speakers you need buy some thing else.
Posted on Nov 12, 2008
Rgb connection stopped working on laptop
Instructions
    • 1 Decide if you want to watch the television on your computer or use the TV as a larger monitor. If you want to view the contents of the TV on your laptop, you need a video card connected to to the computer. These cards can either be inserted through the express PCI card slot on the laptop, or via USB cable. Make sure the video tuner card supports component video.
    • 2 Connect the DVI-to-component cable into the DVI port if you want to use the TV as a large monitor for your laptop. However, if you have a VGA port, plug the VGA-to-component cable into the VGA port.
    • 3 Plug the RGB component cables into the component side of the DVI- or VGA-to-component cable. If you want to watch the TV on your computer, insert the RGB cables into the TV video card.
    • 4 Plug the other end of the RGB component cables into the TV. If you are using the TV as a monitor, plug the cables into the "Component In" ports. However, if you are sending the TV signal to the computer, plug the cables into the "Component Out" port (the other end of the DVI- or VGA-to-component cable that you connected to your computer in Step 2).
    • 5 Power on the TV. If you are using the TV as a computer monitor, press the "Video" button until "Component Video" appears on the screen. If you are watching TV on your computer, launch the television viewing software that came with the TV tuner card. You can now see the contents of the TV on your computer.
Jan 10, 2013 | Dell Computers & Internet
How to watch movie direct from my seagate portable hard drive.
You need to connect the computer to the tv and the seagate to the computer.
You will need to connect the computer and tv by using a cable and connect them. Your TV has ports such as VGA, S-Video or HDMI on it to allow it to receive a signal from some external device. Your computer needs to have the same type of port or you will need something (some type of adapter) to make the tv and computer think they have the same type of connecting ports. Most laptops have an extra port for displaying on an external device such as a tv. Most desktops don't have an extra port so you will need to purchase a video (graphics) card that has the ports on it and install it into one of the desktop's pci slots.
Once you have the ports on both devices (tv and computer) then connect them with a cable. Then take the tv's remote and press Select Input so you can tell the tv where to receive the signal from (PC, VGA, S-Video, HDMI). Reboot the computer and the image should appear on the tv.
On laptops The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 01, 2012 | Seagate FreeAgent® GoFlex? Black 1TB...
I have a Philips 47" flat screen it has HDMI
First of all you must check that your laptop supports a protocol called "DHCP" over DVI. Otherwise you are chasing your tail. This information will probably be in the manual or available online. DHCP is a special handshake protocol for HDMI and your television and computer will not talk to eachother without it. If you find it to be compatible you need to lock down which input on the TV it is. Plug something in via HDMI and verify you see it. Then unplug it and plug your computer into this port. You don't want to be flicking through inputs trying to find it. Also, hook up an external monitor to the laptop and figure what needs to be done to display on it. Then try the television. My guess, though, is that you won't find DHCP compatibility if it is an older laptop. My best advice is to buy a Playstation 3 and watch Netflix with that. Otherwise you'll need a different way of hooking up which might include buying an expensive converter box and/or watching poor quality video.
-Good luck
Apr 24, 2011 | Philips Televison & Video
How can I watch a DVD on my TV from my Inspiron
if u have a TV out signal port on ur laptop, u will need a DIN adaptor to connect from laptop to ur TV
else u need a convertor box that will convert ur connect to ur VGA out port on ur laptop and will send the signal to TV via the box to the audio/video in slot in the TV...u will also need some special cables...thsi will come along with the convertor box....look in google or ebay
Feb 04, 2010 | Dell Inspiron 6400 Notebook
I have a Dell computer that runs Windows Vista and I want to hook it up to use my TV as a monitor to watch a webcast. Please advise.
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
NEED MOre HELP check this link for video :
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Jan 20, 2010 | Computers & Internet
Need to hook up laptop to TV
If you have an HDMI port you might also have an RGB port, use your tv video source button and go through your options. If RGB option is listed you have it. It's a standard moniter port, you can use a standard monitor cable to hook things up. This will not however carry sound so you'll need a basic 3.5mm size cable that ends in an RCA plug (can be picked up radio shack.
I use this method to watch hulu.com movies on my 50" plasma tv.
Another option if you have an "S" video on both the laptop and the tv, use that with just an "S" video cable.
Other wise look for a RGB cable that converts to standard RCA stereo plugs again Radio Shack should be able to help you. You can also buy cables on eBay a lot cheaper then a retail store.
Aug 19, 2009 | Acer Aspire 5720-6661 Notebook PC
Notebook connection to tv
S-Video - This is probably the most common method out there currently because an S-Video cable is cheap as heck and just about every TV under the sun has a S-Video port. You’ll have to make sure you laptop is equipped with this port. Remember, there are two types of S-Video cables: 4-pin and 7-pin. Most laptops and PC’s are equipped with a 7-pin port, so if your TV only has a 4-pin S-Video port, then this method will not work.
Dec 26, 2008 | HP Pavilion dv6000z Notebook
Philips 42PF9946 connect with laptop
Connect to the VGA port on the laptop, using a standard video cable.
Here is how VGA port looks like on your TV:
Note on some laptop you need to activate external video output by pressing a combination of keys, this will swap between laptop LCD video and external video.
Sep 13, 2008 | Philips 42PF9946 42 in. EDTV-Ready Plasma...
No picture
Hey motherann,
If your TV has only been having problems displaying a picture when using the DVD player (and normal TV stations are unaffected), you may only need to check the connections between your TV and DVD player to resolve the issue.
Most DVD players will connect to a TV using component video cables, an HDMI cable, a composite video cable, or an S-Video cable. HDMI and S-Video ports generally have a unique enough shape that the cables used to make those connections cannot be used anywhere else, but the same unfortunately does not apply to component and composite cables. Component and composite video cables share a similar shape, and can often be confused if the identifying marks on the cable itself, TV or DVD player have been removed. Composite video cables are traditionally a single connection that transmits the entire video signal from the DVD player to the TV, while component cables are a series of three cables that each transmit a portion of the same image.
The first thing I would suggest checking is that each cable is correctly connected to both the DVD player and your TV. Make sure that the cable(s) connected to your DVD player is plugged into the appropriate "Video Out" port, and attached to the TV at the corresponding "Video In" port. These ports should be labeled on both the TV and DVD player for easy identification, regardless of where the connections are located. Additionally, many manufacturers will even color-code both the connection ports and the cables themselves, to ensure that the right cable is used at any given time.
In the event that everything has been set up correctly but the TV still does not pick up a video signal from the DVD player, there could be a number of other potential problems: the cable being used could be defective, one of the connection ports used (on either the DVD player or TV) could be defective, or they may even be a loose connection inside the TV or DVD player.
Replacing a defective cable is generally the easist possible solution to this type of scenario, but if the problem still persists after doing so, you may wish to consult a repair technician to determine the cause of the problem.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 24, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Toshiba Satellite A55 Tecra Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
