Question about SanDisk Sansa e200 MP3 Player
Have music on my sansa e250 but my computer says
I am trying to format and erase the songs I have. I have about 73 songs and when I go to windows media player to try and do this it s saying that there are no music files in player. When in fact there are
  • 80 Answers
To format the pm3 use "My Computer" right click on the drive choose format then a window appears
at the bottom left click ok then it will format the mp3
Posted on Nov 14, 2008
My sansa e250
If you want to delete EVERY track off the player, then reformat the player in Windows Media Player - it's a shortcut - see my "tips and tricks" on formatting mp3 players
If there are artist, album traces, then you need to click on every subfolder under your device in Windows Media Player and delete every trace that way - tedious, but effective
-Tha Mp3 Doctor
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 04, 2008 | SanDisk Sansa e250 MP3 Player
Cant i plug this thing into my xbox 360?
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 25, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk e250
If the player runs out of battery while transferring songs, you will get this sympton.
Mar 14, 2008 | SanDisk Sansa e250 MP3 Player
Music
Mar 03, 2008 | SanDisk Sansa e250 MP3 Player
Erasing bad music on my player
If you're fine with erasing your whole library, then just format the player. Connect the player to your PC:
1. Open "My Computer".
2. Right click "Sansa e250" and select "format..."
3. Check "quick format" and run.
4. Reapply the firmware from the sandisk website.
...and you're done. the sansa will be totally wiped clean. and now that you have the newest firmware, you shouldn't see this problem again.
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Song duplication
Corrupt DB or music svc sub needs renewing
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Jun 30, 2007 | SanDisk Sansa e250 MP3 Player
Deleting songs from Sandisk
Hi. The minimum requirements of your Sansa E250 is Windows XP and above and Windows Media Player 10 and above. If you're using Windows Media Player 10 or above, your Sansa E250 and its contents should appear on the right pane when you click on the "Sync" tab. You can right click on a song and select "Remove". The songs will be erased permanently from the player. If your songs do not appear on Windows Media Player 10 or above, it is possible that your songs may have been saved on another mode. Your Sansa E250 comes in 2 modes: MTP and MSC. Songs saved on one mode will not be seen by the other mode, and vice versa. There are 2 ways to delete songs from your Sansa E250: By browsing the folders containing the songs, or by formatting the player. You can switch modes by navigating your E250's menu using the following: Menu >> Settings >> USB Mode Next, plug your player in your PC and open Windows Explorer. You should first set your Explorer to "Show hidden Files and Folders" by going to the "Tools" menu (located on menu lists on Windows Explorer window), then choosing "Folder Options", then enabling the "Show Hidden Files and Folders" radio button Deleting Music files under MTP Mode: 1. Your player should appear as a Sansa E250 icon in Explorer as a "Portable Audio Device". Double left-click this icon to browse the player. 2. You'll find a "PPI NAND" sub-folder. Again, double left-click on this sub-folder. 3. You'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it. 4. Your music should appear as individual files or folders. Delete this to remove the file(s) from the player Deleting Music files under MTP Mode: 1. Your player should appear as a Drive letter and entitled either as a "Removable Drive" or as "Sansa E250" 2. Double left-click on this drive letter to browse the player 3. You may find your music files immediately on this folder, or you'll find a series of sub-folders, one of which should be titled "Music". Double left-click this to open it and view your music files. 4. Delete the music files you want, and they should be removed from the player Deleting files through Format: 1. Formatting the player erases all files in the player, and oftentimes this is the best option to ensure that all files are removed and any corruption eliminated. Also, it is best to format the player when in MSC mode. 2. When the appears as a drive letter (under MSC mode), right-click on that drive letter and select "Format". On the "Format" pop-up window, click "Start" to begin the format process. 3. Follow the on-screen prompts and safely remove the player from your PC when the "Format Complete" display appears. 4. Unplug the player from the PC and when the player is powered up, the message "No Files" should appear on the player's LCD screen 5. Switch the mode back to "MTP", or continue to use "MSC". Note: It is best to use "MTP" when you are transferring subscription music to the player. I hope this helps. :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
Mp3 sansa e250--problem with music
Renew your sub
-Tha Mp3 Doctor
Feb 21, 2007 | SanDisk Sansa e250 MP3 Player
My e250 wont play some songs, they are marked as unknown
-Tha Mp3 Doctor
Jan 28, 2007 | SanDisk Sansa e250 MP3 Player
I click on a song on my sansa e250 then a different song plays
DB corrupt
-Tha Mp3 Doctor
Dec 22, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Sanath Kumar V
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
