Question about Garmin GPS
The sound on my nuvi 750 breaks up. It does it regardless of which vehicle I'm. It doesn't matter whether I have the sound coming through the Garmin speaker, the FM transmitter option, or an earphone/cassette adapter. Also doesn't make any difference whether I'm using the internal battery or cigarette lighter adapter assembly.
  • ponderwh Nov 28, 2008
    I have had my Garmin nuvi 750 for two days. The sound breaks up about 30% of the time. Since the unit is brand new, this is pretty annoying and discouraging! Can anyone suggest a fix, other than returning the unit?
  • pibaul Dec 01, 2008
    From pibaul, (Nov. 12). I returned my first one. Second one does the same thing. Also, 'Audio Directions' inoperative now. Media player works, both through GPS speaker and through headphone jack. If this wasn't my third Garmin GPS, I would swear off that brand.
  • Garmin Master
  • 2,130 Answers
The fact that it appears on speaker, FM & headphone jack, tells me its a problem in the audio output stage.
- Jim
Posted on Nov 13, 2008
Nuvi 750 Car charger connection is intermittent.Either the Car charger or the Nuvi 750 connection is intermittent. The device will display a warning that it is using the battery - 27 seconds to turn o
It is very rare that it would be a problem with the Nuvi 750 GPS itself. This is because there are stationary gold pads on the bottom of the 750. No moving parts to wear out. We have seen problems with a bad plug on the charger that plugs into the cradle and the receptacle on the cradle can go bad as well. I would suspect more toward the cradle as we have seen the receptacles break away from the printed circuit board that is inside of the cradle. Best way to troubleshoot is to find a friend who has a duplicate charger and cradle and swap each piece, one at a time and see which resolves the problem... either the cradle is bad or the charger plug is bad. If you want us to test your unit, cradle and charger, let us know. Good luck! :) More info on charger issues here:
http://www.sharc.net/gps_charger_repair.htm
Apr 21, 2013 | Garmin nuvi 750 GPS Receiver
Nuvi wont turn on
No the red light comes on to show that there is power going to the Satnav. In most Garmins the Battery Strength meter is in the home screen. Generally people leave the satnav plugged in when driving regardless of whether the battery is charged or not.
Jul 16, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 750 went dead when i got it to
Hello :
Resetting your GPS could solve the problem .
Here is how to reset your NUVI :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 17, 2010 | Garmin nuvi 750 GPS Receiver
No sound from nuvi 750
Google Garmin nuvi 750, specify problem, and ~ 8M of corrected software will be downloaded to fix the problem
Jun 21, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Text to speech voice breaks up when giving directions
Try updating the Firmware on the Garmin site www.mygarmin.com
Try changing the language to another voice instead of using Jill try the other one, then return see if it fixes
Apr 12, 2009 | Garmin Nuvi 760 Car GPS Receiver
Sound breaks up when direction are spoken
Connect your unit to your computer with the USB cable, go to Garmin.com and update your software from the "SUPPORT" tab. This should fix you sound problem unless it is caused by a broken speaker. Also see http://www.sharc.net/gps_audio_repair.htm for additional information.
Mar 17, 2009 | Garmin nuvi 750 GPS Receiver
Download software update 4.80 released 5/11/2009, fixed this problem on my Gramin 750
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
No car radio / stereo for use with Garmin nuvi 750 GPS
Every Garmin Nuvi unit I've seen has a (loud) built-in speaker. The only demand our 250s and 265 make of the vehicle is a 12V power supply (and they'll even work without that for a while, until the battery goes flat).
A.
Dec 17, 2008 | Garmin nuvi 750 GPS Receiver
NO SOUND ON GARMIN 750
I had the same problem. I fixed it by going to settings, then to language, and then entering American English into the Voice category. Hope this helps.
Nov 19, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
GPS Logo
150 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
