Question about Microsoft Xbox 360 Console
Sound but not picture
How do I fix this got new cable
  • biggmattt Nov 14, 2008
    i have the same problem and i have gotten many new microsoft and third-party cables and nothing has worked
Are you using official, Microsoft-branded Xbox 360 cables? If not, then your third-party cables are faulty. Always buy accessories that have a :sound but not picture - f4364ba.jpg
Posted on Nov 14, 2008
Why doesn't my XBox 360 show a picture on the tv
Most likely a damaged AV output socket , possibly lifting of the solder joins,
Jun 11, 2014 | Microsoft Xbox 360 Console
I have a 7 yr old sony kf50we610 rear projection lcd tv. Two years ago the picture and sound started going off and coming back on. I replaced the bulb and it solved the problem. Now two days ago the...
As it was explained in live chat session, cable box needs reset/ reboot because tv has normal picture in other inputs.
After resetting/ rebooting cable box, problem is solved.
Jan 15, 2011 | Televison & Video
The bulb will come onthen off for three time then nothingnow i have plug cable into ant. Port i can get sound off cable box on any show playing but no picture. Then when move to cable plug in i get no...
First make sure that your cooling fan is running to keep the bulb cool. If not it's likely that you will need to replace that. If it is running it may be as simple as a failing bulb. If it has been in there for quite awhile or since new try replacing it. Those are the most common fixes for that set. I suspect one of them will fix your defect.
Jun 23, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Just bought tv plugged in with cable no picture
Take it back, demand a NEW unit, this is unacceptable. Unit unfit for sale. Consumer Guarantee act says must work for the purpose intended for and MUST be fixed by seller, NO repair replacement,
Mar 30, 2010 | Televison & Video
My Toshiba 50 A 50 rear projection has great sound but no picture. Can you help tell me if I need a fuse or bulb?
This TV does not use a bulb. It is a Picture tube type set.
*No picture but there is a dim background. Menu works.
This is caused by a bad signal. Perhaps the video cable is bad if you use a cable box. The HDMI cable may not be working right. Try a new cable.
*No picture, no menu
This could be caused by a failure in the part that draws the picture up and down (The vertical). Can also be the side to side (Horizontal) or a high voltage problem. The last usually kills the sound as well so its not as likely.
If the cable does not fix it, you will likely need a technician.
Mar 21, 2010 | Toshiba 50A50 50" Rear Projection...
Sound but no picture
Start by eliminating the variables. Connect a source that you know is working (e.g. a VCR or DVR that is working on another TV) to your TV. If you get the same result, connect it to a different input and, if possible, different input type. If you still get the same result, your TV is bad. Most standard TVs are not worth fixing since it costs almost as much to fix them as to purchase a new one.
If changing the input fixes the problem, the TV has a bad input and you can just switch to a new input.
If changing the source fixes the problem, your source is bad and needs to be repaired or replaced.
Be sure to use cables that you know to be good by testing them on another source/TV system.
If changing the cables fixes the problem, then replace the cables.
Dec 05, 2009 | Cell Phones
Bad picture with Sega Genesis model 1
Taking your problem in a whole new direction, why don't you try purchasing an 8 or 9-pin (depending on the type of Genesis you have) DIN RCA cable. This will improve picture and sound, and you won't have to worry about malfunctioning RF converters. Your problem sounds like the RF adapters are inadequate.
Sep 16, 2009 | Nintendo Super NES Console
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 26, 2008 | Insignia LCDTV26 26 in. Television
Picture is fine, but the sound won't work
Are the yellow, red & white cables RCA phono plugs?
Yellow = Video
Red = Right Audio
White = Left Audio (mono)
The red, blue & green cables are for picture only and don't include sound. Have you tried using the red, blue & green for the picture and using the other cable, red & white for just the sound? Don't use the yellow.
- Jim
Feb 10, 2008 | Sanyo HT32744 32" TV
Microsoft Xbox 360 Console Logo
26 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
